i know this has been asked before, what is required to
#2253384
02/14/17 04:16 AM
02/14/17 04:16 AM
Posts: 298 CA
David Lee
CA
convert to larger front brakes on a 67 cuda?
Ah...so many pedestrians, so little time...
Re: i know this has been asked before, what is required to
[Re: David Lee]
#2253394
02/14/17 05:06 AM
02/14/17 05:06 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
It depends on what size your talking about taking off and if your converting from drums to disc brakes or not If your switching from 9 inch drums to the later model(1973 to 1976) A body disc brakes with the big bolt pattern you will need the upper and lower control arms with the ball joints, spindles and all the brake mounting brackets, hardware and disc and calipers mounting bolts and switch to a proper size for your car disc brake master cylinder I did this on my 1971 Duster with the early small bolt pattern disc brakes, I swapped the passenger side to the drivers side on the later model caliper mounting brackets and brake calipers to get that heavy weight single piston caliper behind the spindles
[Re: David Lee]
#2253398
02/14/17 05:31 AM
02/14/17 05:31 AM
Posts: 298 CA
David Lee
CA
i want to switch to the larger later date drum brakes
[Re: David Lee]
#2253401
02/14/17 05:38 AM
02/14/17 05:38 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
i want to switch to the larger later date drum brakes Why do you want front drum brakes?
[Re: David Lee]
#2253570
02/14/17 03:42 PM
02/14/17 03:42 PM
Cab_Burge
Are you wanting to swap to the bigger 10 inch A body brakes or the bigger B body drum brakes? Either way I'm not sure what you need to do that swap either way Sorry. If your wanting the lightest weight front brake on your car one of the after market racing front disc conversion kits with aluminum calipers may be lighter than any of the stock drum brakes set ups I have a 1965 dart 270 that I bought a front disc brake conversion for the stock nine inch brake front spindles from Strange Engr. I haven't weighed them against the stock brakes yet due to the car still being under construction and I haven't mounted all the front brake parts yet The car was a shell only when I bought it with boxes and boxes of parts, it came from Santa Barbara, CA so there is no rust on it to fix or body work to have done
[Re: Cab_Burge]
#2253630
02/14/17 05:19 PM
02/14/17 05:19 PM
Posts: 298 CA
David Lee
CA
then 10 inch A body brakes, i swapped out the old rear for an 8 3/4" rear. This going to be a stocker running in K/SA. if this was going to be a ss car or car with a big block I would go the disk brake route.
[Re: Jim_Lusk]
#2253669
02/14/17 07:10 PM
02/14/17 07:10 PM
Posts: 298 CA
David Lee
CA
I am in the redondo area.
[Re: David Lee]
#2253702
02/14/17 09:04 PM
02/14/17 09:04 PM
RapidRobert
convert to larger front brakes on a 67 cuda? are you staying SBP? some ceramic or velvetouch shoes or haveing a brake specialty shoes rivet on some killer lining material might give you the extra bite you need & not add any weight.
[Re: David Lee]
#2253833
02/15/17 12:38 AM
02/15/17 12:38 AM
Posts: 298 CA
David Lee
CA
thanks very much, exactly what I was looking for.
[Re: RapidRobert]
#2254214
02/15/17 08:48 PM
02/15/17 08:48 PM
Posts: 298 CA
David Lee
CA
no i am going to the higher performance pads, do not want to end up in the sand
[Re: B5 Bee]
#2254594
02/16/17 02:47 PM
02/16/17 02:47 PM
Posts: 298 CA
David Lee
CA
Quick question I found a set of 1973-76 Large Ball Joint Upper Control Arms. Will those work without any problems?
[Re: David Lee]
#2255086
02/17/17 04:28 PM
02/17/17 04:28 PM
Posts: 25,790 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yes, if you're going the way B5 Bee recommended.
[Re: Jim_Lusk]
#2255300
02/18/17 01:09 AM
02/18/17 01:09 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I did the disc brake change as Cab did but didn't switch sides, seems that extra weight of the calipers really doesn't matter on my Barracuda. Payed $100. bucks for everything and bought new pads.
