A01 Ignition light delay relay mounting location #2252853
02/13/17 11:03 AM
02/13/17 11:03 AM
Ottawa, Ontario
L.R Helbling Offline OP
Ottawa, Ontario
I am crawling under the dash looking for the block connecter used for the relay noted above. Have no idea what it looks like and where it is supposed to mount. Any clues?
Pics of the block connector and coloured wire would help a lot.
Re: A01 Ignition light delay relay mounting location [Re: L.R Helbling] #2252857
02/13/17 11:10 AM
02/13/17 11:10 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I think it is taped to the column if memory serves me right. The service manual will show the shape, and wires for the connector.
Re: A01 Ignition light delay relay mounting location [Re: 71birdJ68] #2253014
02/13/17 04:49 PM
02/13/17 04:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
yes, it is taped to the column. that's what the black stuff is on the unit in this pic i found
rats, that didn't work as planned!
here's a link to it - http://s1093.photobucket.com/user/dstrzelec/media/DSC_5653.jpg.html
Re: A01 Ignition light delay relay mounting location [Re: L.R Helbling] #2253049
02/13/17 05:46 PM
02/13/17 05:46 PM
Ottawa, Ontario
Ottawa, Ontario
That's exactly what I needed to see. 2 yellow wires and a pink wire going to the block connector and, of course, the relay is pushed into the connector. I'll have a look around the column to see if I can find the block connector there. Thanks guys!
Re: A01 Ignition light delay relay mounting location [Re: L.R Helbling] #2253100
02/13/17 07:14 PM
02/13/17 07:14 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if memory serves, it's a 3 hole female bullet connector
Re: A01 Ignition light delay relay mounting location [Re: mikemee1331] #2253109
02/13/17 07:47 PM
02/13/17 07:47 PM
Ottawa, Ontario
Ottawa, Ontario
They are spade lock terminals in a black block connector. I opened the link that you provided and had a good long look at the picture. It's somewhat clear. Anyway, I do have the relay which I was fortunate to get at the dealer and 2 of the terminals are parallel to each other and the pink one is at a right angle to the others. All I have to do is find that block connector, if it's somewhere near the steering column, and plug the relay into it and my ignition light and map light should both come on and time off when the door is open.
Re: A01 Ignition light delay relay mounting location [Re: L.R Helbling] #2253143
02/13/17 08:48 PM
02/13/17 08:48 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i don't have a clue what car you are working on so i'm shooting in the dark based on my 69 RR. my car did not come with that light package but i loved it in my first RR many, many moons ago. i added it this car from who knows what out of a junk yard 30 some years ago. i didn't mess with the connectors when i took it out and i'm pretty sure the yellow wire had a bullet connector.
anyway, you said you found your timer relay at a dealership?? care to share that part number? i'd like to get a spare.
Re: A01 Ignition light delay relay mounting location [Re: L.R Helbling] #2253179
02/13/17 10:04 PM
02/13/17 10:04 PM
Ottawa, Ontario
Ottawa, Ontario
I"m working on a 71 RR with the A01 light group. Apparently they are still available for my car as well as for mini vans made up to the 90s. They are one and the same relay. Part # 2889565. When I ordered the relay from Southbank Dodge Chrysler, the part even came in the old style Mopar red and black box. Which just goes to prove that NOS parts are still available at the dealership.
Re: A01 Ignition light delay relay mounting location [Re: L.R Helbling] #2253476
02/14/17 12:31 PM
02/14/17 12:31 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
In E bodies the time delay relay is just taped to the dash harness.
Craig
Re: A01 Ignition light delay relay mounting location [Re: L.R Helbling] #2253741
02/14/17 10:31 PM
02/14/17 10:31 PM
Ottawa, Ontario
Ottawa, Ontario
Yes, and I believe there is an older thread here on Moparts.com to help explain why.
Re: A01 Ignition light delay relay mounting location [Re: L.R Helbling] #2254555
02/16/17 01:39 PM
02/16/17 01:39 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
What kind of car ?
Best I can remember , On a B body I dont think it attaches to anything except the plug. It just hangs there.
Re: A01 Ignition light delay relay mounting location [Re: L.R Helbling] #2255569
02/18/17 06:02 PM
02/18/17 06:02 PM
Ottawa, Ontario
Ottawa, Ontario
It's a B-body Plymouth. On one of the threads here the poster said that the relay gets hot and needs a heat sink so it is taped to the column. In the pic above provided by MikeMee 1331, you can see some left over tape gum from where it was taped.
