Re: A01 Ignition light delay relay mounting location
[Re: 71birdJ68]
#2253014
02/13/17 04:49 PM
02/13/17 04:49 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I think it is taped to the column if memory serves me right. The service manual will show the shape, and wires for the connector. yes, it is taped to the column. that's what the black stuff is on the unit in this pic i found rats, that didn't work as planned! here's a link to it - http://s1093.photobucket.com/user/dstrzelec/media/DSC_5653.jpg.html
[Re: L.R Helbling]
#2253100
02/13/17 07:14 PM
02/13/17 07:14 PM
mikemee1331
bethlehem pa
That's exactly what I needed to see. 2 yellow wires and a pink wire going to the block connector and, of course, the relay is pushed into the connector. I'll have a look around the column to see if I can find the block connector there. Thanks guys! if memory serves, it's a 3 hole female bullet connector
[Re: mikemee1331]
#2253109
02/13/17 07:47 PM
02/13/17 07:47 PM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
That's exactly what I needed to see. 2 yellow wires and a pink wire going to the block connector and, of course, the relay is pushed into the connector. I'll have a look around the column to see if I can find the block connector there. Thanks guys! if memory serves, it's a 3 hole female bullet connector They are spade lock terminals in a black block connector. I opened the link that you provided and had a good long look at the picture. It's somewhat clear. Anyway, I do have the relay which I was fortunate to get at the dealer and 2 of the terminals are parallel to each other and the pink one is at a right angle to the others. All I have to do is find that block connector, if it's somewhere near the steering column, and plug the relay into it and my ignition light and map light should both come on and time off when the door is open.
[Re: L.R Helbling]
#2253476
02/14/17 12:31 PM
02/14/17 12:31 PM
Posts: 1,822 Colorado
denfireguy
Colorado
In E bodies the time delay relay is just taped to the dash harness. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
