Page 1 of 5 1 2 3 4 5
Project big block a body headers. #2250098
02/09/17 01:02 AM
02/09/17 01:02 AM
fresno ca
mikeysmopars Offline OP
fresno ca
Well after getting my engine rebuilt last year and changed everything from the transmission tunnel forward including a Bob's profab tube front end I ran my original 1 7/8" hooker fender wells which obviously left room for improvement, bought a set of Mazzolini/Tti Proparts 2 1/8 stepped headers and ended up going 2 tenths quicker with only a header change and bumping the timing from 36 to 38. Only problem was I hate in chassis headers so my quest to get some fender well headers made that would breathe and somewhat easy to work on. Some of the members here recommended RMS in Arizona which I was seriously concidering but a friend told me of a local guy. Went to check out his work and ended up having him make me a set. I cut my firewall to sink them back and as soon as I get them boxed in I'll shoot some pix of it finished but here are a couple of them after coating.
Go ahead with your thoughts.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Project big block a body headers. [Re: mikeysmopars] #2250111
02/09/17 01:24 AM
02/09/17 01:24 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Very very nice, how long are they ?
1963 Plymouth Max Wedge
1971 Barracuda
Re: Project big block a body headers. [Re: ozymaxwedge] #2250118
02/09/17 01:36 AM
02/09/17 01:36 AM
fresno ca
fresno ca
To the collector they are about 63"
He used 572 flanges and made them from 16 guage pipe. 2 1/8 to 2 1/4 to 4" collectors. They are heavy but I can work on every aspect of the car without removing them.
Re: Project big block a body headers. [Re: mikeysmopars] #2250121
02/09/17 01:41 AM
02/09/17 01:41 AM
fresno ca
fresno ca
Pretty sweet welds.
Re: Project big block a body headers. [Re: mikeysmopars] #2250210
02/09/17 09:42 AM
02/09/17 09:42 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks good! My next project will have those V-band clamps, not sure what I'm doing wrong with my Walker band clamps but they keep crimping my pipes even when I oil them.
Re: Project big block a body headers. [Re: mikeysmopars] #2250263
02/09/17 12:10 PM
02/09/17 12:10 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Have you tried to put them in the car yet?Did you think about putting a slip tube fit splitting the length?
Re: Project big block a body headers. [Re: ProSport] #2250272
02/09/17 12:40 PM
02/09/17 12:40 PM
moparx Online content
moparx  Online Content
do you have a pic on how the crimp looks ?
beer
Re: Project big block a body headers. [Re: mikeysmopars] #2250276
02/09/17 01:01 PM
02/09/17 01:01 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
No I do not. I'll take a pic next time, seems to do it on the butt joint and lap joint band clamps.
Re: Project big block a body headers. [Re: Clanton] #2250498
02/09/17 05:59 PM
02/09/17 05:59 PM
fresno ca
fresno ca
They were built on the car and I didn't want slip tubes. as big as these are they come out one piece. I had to cut into the firewall to have them go back far enough for a 26" tall front runner and I'm boxing them in as we speak. I'll send more pix after they are done.
Re: Project big block a body headers. [Re: mikeysmopars] #2250516
02/09/17 06:28 PM
02/09/17 06:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That would make for an interesting dyno test.
As i recall......On a mid-600hp 493, 2" Hooker fenderwells were down about 35hp to my dyno headers.
63" is going to tune to a pretty low rpm.
Re: Project big block a body headers. [Re: mikeysmopars] #2250524
02/09/17 06:38 PM
02/09/17 06:38 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Originally Posted By mikeysmopars
Pretty sweet welds.
Mike those are crazy long..👓
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Project big block a body headers. [Re: mikeysmopars] #2250525
02/09/17 06:39 PM
02/09/17 06:39 PM
fresno ca
fresno ca
Side when I picked it up.
Re: Project big block a body headers. [Re: fast68plymouth] #2250528
02/09/17 06:46 PM
02/09/17 06:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep I agree... those are WAY to long to match
the engine
wave
Re: Project big block a body headers. [Re: mikeysmopars] #2250535
02/09/17 07:02 PM
02/09/17 07:02 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I'd love to have a set made like the stahl or proparts but better suited to fit my car. Having to modify my headers now so that I can get to the shock adjustment knob.
Adriel Paradise
Substation Design Engineer III
Re: Project big block a body headers. [Re: fast68plymouth] #2250537
02/09/17 07:02 PM
02/09/17 07:02 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
iagree As soon as I saw 63", your old dyno tests with the longer headers came into my mind. Said , oh no, maybe not so good.
Edit; ok, I see they are 2"1/8 to 2"1/4 pretty quick. That might be just fine. 2"1/4 is pretty huge, it may want that 63" This would make a dyno test pretty interesting as stated.
Re: Project big block a body headers. [Re: Sport440] #2250579
02/09/17 08:02 PM
02/09/17 08:02 PM
fresno ca
fresno ca
iagree As soon as I saw 63", your old dyno tests with the longer headers came into my mind. Said , oh no, not so good.
Going to run in two weeks so I have no choice but to run them and if it hurts my ET my plan is too have him shorten them like the headman hustler style headers which would take about 12 to 14 inches out of them but put the collector right in the firewall. If it actually gains from my last outing im gonna leave them alone.
Re: Project big block a body headers. [Re: mikeysmopars] #2250583
02/09/17 08:07 PM
02/09/17 08:07 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You made what you wanted,looks good.My collector slips on at the frame level so a good 20 shorter than yours.You could always cut your down.
Re: Project big block a body headers. [Re: Sport440] #2250596
02/09/17 08:21 PM
02/09/17 08:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No way... they are way too long... have you EVER seen
a 63" long primary tube header.. then add the collector..
that guy made them fit to what the guy wanted.. way out
of spec for the engine
EDIT
How long is the collector
wave
Re: Project big block a body headers. [Re: mikeysmopars] #2250608
02/09/17 08:37 PM
02/09/17 08:37 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
run it have some fun..it is to bad you were not going back to the dyno
Re: Project big block a body headers. [Re: mikeysmopars] #2250631
02/09/17 09:06 PM
02/09/17 09:06 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Read my post again, edited it 5 minutes before this post of yours. up
