Six pack carb rebuild kits..... #2248521
02/06/17 03:27 PM
02/06/17 03:27 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
Who sells the most complete rebuild kits for six pack carbs ?? I may just need the center carb kit. Carbs are newer repro 71 carbs ...... thanks.
Re: Six pack carb rebuild kits..... [Re: THESHAKERPROJECT] #2248587
02/06/17 04:42 PM
02/06/17 04:42 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
I just ordered a kit from Chicago Carburetor:
www.chicagocarburetor.com
Their kits use black gasket material. The new Holley fuel bowl kits use blue rubber gaskets, which can be a problem if you are going for that OE look.
I have yet to use the kit, but all components appear to have good quality and construction, etc.
Re: Six pack carb rebuild kits..... [Re: B5Cuda440-6] #2248590
02/06/17 04:57 PM
02/06/17 04:57 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's good to know up
Re: Six pack carb rebuild kits..... [Re: THESHAKERPROJECT] #2248737
02/06/17 09:49 PM
02/06/17 09:49 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
I just finished up my carbs:
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: Six pack carb rebuild kits..... [Re: FM3AAR] #2248861
02/07/17 12:35 AM
02/07/17 12:35 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Nice!! I bet you're happy with that... up
Re: Six pack carb rebuild kits..... [Re: screamindriver] #2248887
02/07/17 01:19 AM
02/07/17 01:19 AM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
Thanks.
Lots of parts left over from buying 3 kits.
I just wish Holley would put out a single kit containing all the parts needed to rebuild all 3 carbs at once on the SixPacks/427 TriPowers. up
K. Schwab
Re: Six pack carb rebuild kits..... [Re: FM3AAR] #2248935
02/07/17 02:54 AM
02/07/17 02:54 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
What did you do to achieve that beautiful nice satin finish? So often one sees a very weird in your face goldish look. Nice work
Re: Six pack carb rebuild kits..... [Re: Sxrxrnr] #2248945
02/07/17 03:14 AM
02/07/17 03:14 AM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
I couldn't afford Holley's replating service so I went with Eastwood's carb paint.
K. Schwab
Re: Six pack carb rebuild kits..... [Re: FM3AAR] #2249074
02/07/17 01:51 PM
02/07/17 01:51 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That looks pretty nice compared to correct dichromate finish ! up
Re: Six pack carb rebuild kits..... [Re: THESHAKERPROJECT] #2249181
02/07/17 05:06 PM
02/07/17 05:06 PM
Chicago
PurpleBeeper Offline
Chicago
I've had good luck with both the Holley 37-396 and the chicago carburetor kits. If you've rebuilt a few of these and are familiar with where everything goes, there's somebody on ebay that sells a kit for all three carbs with pieces loose in zip lock baggies & I had good luck with that kit too.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Six pack carb rebuild kits..... [Re: THESHAKERPROJECT] #2249293
02/07/17 08:32 PM
02/07/17 08:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Mike - Do you need all the gaskets, or just metering block & float bowl gaskets? I don't think that I have any of the main body to base plate gaskets left, but definitely have metering block & float bowl gaskets. Call/text me if I can help.
