Re: Six pack carb rebuild kits.....
[Re: THESHAKERPROJECT]
#2248587
02/06/17 04:42 PM
02/06/17 04:42 PM
Posts: 567 Indianapolis, IN
B5Cuda440-6
Indianapolis, IN
I just ordered a kit from Chicago Carburetor: www.chicagocarburetor.comTheir kits use black gasket material. The new Holley fuel bowl kits use blue rubber gaskets, which can be a problem if you are going for that OE look. I have yet to use the kit, but all components appear to have good quality and construction, etc.
[Re: B5Cuda440-6]
#2248590
02/06/17 04:57 PM
02/06/17 04:57 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I just ordered a kit from Chicago Carburetor: www.chicagocarburetor.comTheir kits use black gasket material. The new Holley fuel bowl kits use blue rubber gaskets, which can be a problem if you are going for that OE look. I have yet to use the kit, but all components appear to have good quality and construction, etc. That's good to know
#2248737
02/06/17 09:49 PM
02/06/17 09:49 PM
Posts: 2,351 Banana Republic
FM3AAR
Banana Republic
I just finished up my carbs:
“You’ll own nothing” — And “you’ll be happy about it.” K. Schwab
[Re: screamindriver]
#2248887
02/07/17 01:19 AM
02/07/17 01:19 AM
FM3AAR
Banana Republic
Thanks. Lots of parts left over from buying 3 kits. I just wish Holley would put out a single kit containing all the parts needed to rebuild all 3 carbs at once on the SixPacks/427 TriPowers.
[Re: FM3AAR]
#2248935
02/07/17 02:54 AM
02/07/17 02:54 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I just finished up my carbs: What did you do to achieve that beautiful nice satin finish? So often one sees a very weird in your face goldish look. Nice work
[Re: Sxrxrnr]
#2248945
02/07/17 03:14 AM
02/07/17 03:14 AM
FM3AAR
Banana Republic
I couldn't afford Holley's replating service so I went with Eastwood's carb paint.
#2249181
02/07/17 05:06 PM
02/07/17 05:06 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I've had good luck with both the Holley 37-396 and the chicago carburetor kits. If you've rebuilt a few of these and are familiar with where everything goes, there's somebody on ebay that sells a kit for all three carbs with pieces loose in zip lock baggies & I had good luck with that kit too.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
#2249293
02/07/17 08:32 PM
02/07/17 08:32 PM
BradH
Who sells the most complete rebuild kits for six pack carbs ?? I may just need the center carb kit. Carbs are newer repro 71 carbs ...... thanks. Mike - Do you need all the gaskets, or just metering block & float bowl gaskets? I don't think that I have any of the main body to base plate gaskets left, but definitely have metering block & float bowl gaskets. Call/text me if I can help.
