727 build question #2247113
02/04/17 12:06 PM
02/04/17 12:06 PM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
I have a 727 core from a 1972 440 powered C body that I'm going to have built up for use in my Coronet. The Coronet will be a driver with a mildly built 440, streetable torque converter and a 3:55 rear. It will be mostly street driven with an occasional pass at the strip. The trans currently has a 3.2 kick down lever in it and I was wondering if a 3.8 or 4.2 lever upgrade would be a good idea. Thxs
Re: 727 build question [Re: Casey] #2247229
02/04/17 03:59 PM
02/04/17 03:59 PM
scratchnfotraction Offline
IMHO yes. I used a 3.8 on mine.
also rebuilt it with new frictions/steels/front/rear bands/seals
new CRT-TF-2 shift kit valve body, CRT-billet front/rear servos
Re: 727 build question [Re: Casey] #2247392
02/04/17 09:53 PM
02/04/17 09:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
3.2 will work fine for your application. Make sure you use 4 clutches in the high drum.
Doug
Re: 727 build question [Re: dvw] #2247449
02/04/17 11:18 PM
02/04/17 11:18 PM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
Thanks for the feedback. One other thought. If the present 440 was swapped out for a similarly built, pump gas friendly 496 down the road. Would the 3.2 still be a decent choice?
Re: 727 build question [Re: Casey] #2247669
02/05/17 12:43 PM
02/05/17 12:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Depends on usage. On the street it will provide a calmer 1-2 shift. Many guys that run FAST class use 2.9. My 9.0@149 car only runs a 3.8 with excellent clutch and band life.
Doug
Re: 727 build question [Re: Casey] #2248432
02/06/17 01:31 PM
02/06/17 01:31 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Another problem with the 1972 C body core will be the 4500rpm full throttle upshifts. Rick at A & A Transmission has the cure for this.
Re: 727 build question [Re: Casey] #2248507
02/06/17 03:08 PM
02/06/17 03:08 PM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
Magnum Thxs. I'm a transmission newbie. Just guessing here, being a C body trans it shifts early at WOT compared to an HP unit. Checked out A&As site. He shows multiple governor kits for different RPM shift points. My cam is all done at 5200, so I would use the correlating RPM trans governor?
Re: 727 build question [Re: Magnum] #2248579
02/06/17 04:34 PM
02/06/17 04:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Only if you leave it in Drive....manual shifting is a wiser and cheaper option.
Re: 727 build question [Re: John_Kunkel] #2248648
02/06/17 06:45 PM
02/06/17 06:45 PM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
John that makes sense. Any opinion on the 3.2, 3.8 or 4.2 lever choice? Thxs
Re: 727 build question [Re: Casey] #2248690
02/06/17 08:31 PM
02/06/17 08:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'd go with the 3.8 or 4.2
Re: 727 build question [Re: Casey] #2248778
02/06/17 10:37 PM
02/06/17 10:37 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What do you mean by "all done"? What is the cam size?
Re: 727 build question [Re: Casey] #2248872
02/07/17 12:57 AM
02/07/17 12:57 AM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
Just a 268H Comp Cams hydraulic, 1200-5200 RPM range.
