Re: 727 build question
[Re: Casey]
#2248432
02/06/17 01:31 PM
02/06/17 01:31 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Another problem with the 1972 C body core will be the 4500rpm full throttle upshifts. Rick at A & A Transmission has the cure for this.
[Re: Magnum]
#2248579
02/06/17 04:34 PM
02/06/17 04:34 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Another problem with the 1972 C body core will be the 4500rpm full throttle upshifts. Only if you leave it in Drive....manual shifting is a wiser and cheaper option.
[Re: Casey]
#2248690
02/06/17 08:31 PM
02/06/17 08:31 PM
John_Kunkel
Rio Linda, CA
I'd go with the 3.8 or 4.2
[Re: Casey]
#2248778
02/06/17 10:37 PM
02/06/17 10:37 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
Magnum Thxs. I'm a transmission newbie. Just guessing here, being a C body trans it shifts early at WOT compared to an HP unit. Checked out A&As site. He shows multiple governor kits for different RPM shift points. My cam is all done at 5200, so I would use the correlating RPM trans governor? What do you mean by "all done"? What is the cam size?
