Caltac set up #2247459
02/04/17 11:38 PM
02/04/17 11:38 PM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
Looking at up grading to a caltrac set up will be moving the springs in with the mp relocation kit I was wondering what front segment are you running the stock 20 inch or the 22 inch the car is a 71 duster have heard of some running the 25 inch spring thanks for the help
Re: Caltac set up [Re: scottb] #2247542
02/05/17 02:10 AM
02/05/17 02:10 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
25" here but guys have flown w/the stock 20"............
Re: Caltac set up [Re: scottb] #2247570
02/05/17 03:02 AM
02/05/17 03:02 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
digby has been in the 4's with the 20
Re: Caltac set up [Re: scottb] #2247630
02/05/17 11:39 AM
02/05/17 11:39 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
25" here also. You can make the 20" work but I think the 25" is easier to get work. Look into the slider mount for the rear of the spring instead of the factory shackles also.
Re: Caltac set up [Re: scottb] #2247648
02/05/17 12:18 PM
02/05/17 12:18 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
How quick is the car? The faster the car, the more it could use the long length.
Re: Caltac set up [Re: scottb] #2247656
02/05/17 12:28 PM
02/05/17 12:28 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
If you do use sliders,buy them from Calvert.The speedways are made in China,the Affcos don" have the right hardware for caltrac springs.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Caltac set up [Re: scottb] #2247665
02/05/17 12:40 PM
02/05/17 12:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Can you explain that please.
Re: Caltac set up [Re: scottb] #2247678
02/05/17 12:56 PM
02/05/17 12:56 PM
hemi-itis Offline
hemi-itis  Offline
If you choose to go with sliders,just get then from Calvert.Speedway has the Chinese knock offs that look like Afco.Afco also offers the USA make one at twice the price of the knock offs.I bought the Afco USA ones and the hardware is for MOPAR S/S springs which have a different size spring eye than the Calvert.So I had to buy the bearings & sleeves from Calvert.
Re: Caltac set up [Re: scottb] #2247690
02/05/17 01:29 PM
02/05/17 01:29 PM
a493demon Offline
a493demon  Offline
I thought the slider was suppose to be in the middle of the slot when the susp. is hanging ? I'm going to be putting them on my car soon so just checking .
Re: Caltac set up [Re: hemi-itis] #2247694
02/05/17 01:33 PM
02/05/17 01:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Dude, are those sliders welded it that position cos if so, that's WAY too biased towards the ft.................... work
Re: Caltac set up [Re: scottb] #2247702
02/05/17 01:42 PM
02/05/17 01:42 PM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
Ok thanks for the help car should run mid to low 9s 71 abody 3000 lbs looks like the slider set up and the longer segment in the front what are you guys running for shocks there 9 way shock or a good coil over shock any one have any pictures how your shocks are mounted thank you
Re: Caltac set up [Re: Thumperdart] #2247705
02/05/17 01:46 PM
02/05/17 01:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Looking at the arc of the spring I would guess that it's hanging shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Caltac set up [Re: scottb] #2247711
02/05/17 01:54 PM
02/05/17 01:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run the old 5-ways out back and 90-10's up front...........about 3050 lbs BB 470 1.33 footin it at 2500 so far.............
Re: Caltac set up [Re: fourgearsavoy] #2247734
02/05/17 02:36 PM
02/05/17 02:36 PM
hemi-itis Offline
hemi-itis  Offline
Gus beer
Car is on the lift with axel hanging.They will NEVER go this far foward!
I put them in the middle and the witness marks show they never get too close to the front or the rear.If I were to do it again,,,I would buy the Calvert sliders!
It also lowered the body about nches2 inches.
Re: Caltac set up [Re: scottb] #2247746
02/05/17 02:49 PM
02/05/17 02:49 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Hemi itis your Calvert sliders look identical to my speedway ones, packaging and everything.
My car at rest the spring sits all the way back in the slider, I have hit the front of the slider before when I have had to pedal the car... it makes a hell of a noise
Re: Caltac set up [Re: scottb] #2247756
02/05/17 03:05 PM
02/05/17 03:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This means the spring has no upward movement whatsoever then.
Re: Caltac set up [Re: SpareParts] #2247892
02/05/17 05:55 PM
02/05/17 05:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That don't sound right at all no matter HOW fast you are...........
Re: Caltac set up [Re: Stanton] #2247960
02/05/17 07:29 PM
02/05/17 07:29 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I think you mean downward. if the spring is at the rear of the slider it wont travel down. Spring gets longer with added weight. Spring will go forward as force is applied to the caltrac.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Caltac set up [Re: scottb] #2248071
02/05/17 10:27 PM
02/05/17 10:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
NO, I meant UPWARD ... as in if it goes over a speed bump its got nowhere to go.
Re: Caltac set up [Re: Stanton] #2248364
02/06/17 12:04 PM
02/06/17 12:04 PM
moparx Offline
moparx  Offline
how often should sliders be greased ?
beer
