Re: Caltac set up
[Re: scottb]
#2247542
02/05/17 02:10 AM
02/05/17 02:10 AM
Thumperdart
State of confusion
Looking at up grading to a caltrac set up will be moving the springs in with the mp relocation kit I was wondering what front segment are you running the stock 20 inch or the 22 inch the car is a 71 duster have heard of some running the 25 inch spring thanks for the help 25" here but guys have flown w/the stock 20"............
Re: Caltac set up
[Re: scottb]
#2247656
02/05/17 12:28 PM
02/05/17 12:28 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
If you do use sliders,buy them from Calvert.The speedways are made in China,the Affcos don" have the right hardware for caltrac springs.
Re: Caltac set up
[Re: scottb]
#2247665
02/05/17 12:40 PM
02/05/17 12:40 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
the Affcos don" have the right hardware for caltrac springs. Can you explain that please.
Re: Caltac set up
[Re: scottb]
#2247678
02/05/17 12:56 PM
02/05/17 12:56 PM
hemi-itis
If you choose to go with sliders,just get then from Calvert.Speedway has the Chinese knock offs that look like Afco.Afco also offers the USA make one at twice the price of the knock offs.I bought the Afco USA ones and the hardware is for MOPAR S/S springs which have a different size spring eye than the Calvert.So I had to buy the bearings & sleeves from Calvert.
Re: Caltac set up
[Re: hemi-itis]
#2247694
02/05/17 01:33 PM
02/05/17 01:33 PM
Thumperdart
State of confusion
If you do use sliders,buy them from Calvert.The speedways are made in China,the Affcos don" have the right hardware for caltrac springs. Dude, are those sliders welded it that position cos if so, that's WAY too biased towards the ft....................
Re: Caltac set up
[Re: scottb]
#2247711
02/05/17 01:54 PM
02/05/17 01:54 PM
Thumperdart
State of confusion
I run the old 5-ways out back and 90-10's up front...........about 3050 lbs BB 470 1.33 footin it at 2500 so far.............
Re: Caltac set up
[Re: fourgearsavoy]
#2247734
02/05/17 02:36 PM
02/05/17 02:36 PM
hemi-itis
Looking at the arc of the spring I would guess that it's hanging Gus Car is on the lift with axel hanging.They will NEVER go this far foward! I put them in the middle and the witness marks show they never get too close to the front or the rear.If I were to do it again,,,I would buy the Calvert sliders! It also lowered the body about nches2 inches.
Re: Caltac set up
[Re: scottb]
#2247756
02/05/17 03:05 PM
02/05/17 03:05 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
My car at rest the spring sits all the way back in the slider, This means the spring has no upward movement whatsoever then.
Re: Caltac set up
[Re: SpareParts]
#2247892
02/05/17 05:55 PM
02/05/17 05:55 PM
Thumperdart
State of confusion
Hemi itis your Calvert sliders look identical to my speedway ones, packaging and everything. My car at rest the spring sits all the way back in the slider, I have hit the front of the slider before when I have had to pedal the car... it makes a hell of a noise That don't sound right at all no matter HOW fast you are...........
Re: Caltac set up
[Re: Stanton]
#2247960
02/05/17 07:29 PM
02/05/17 07:29 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
My car at rest the spring sits all the way back in the slider, This means the spring has no upward movement whatsoever then. I think you mean downward. if the spring is at the rear of the slider it wont travel down. Spring gets longer with added weight. Spring will go forward as force is applied to the caltrac.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
