A body cal-trac vertical shock #2247333
02/04/17 08:09 PM
02/04/17 08:09 PM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
My 69 dart has caltracs and spilt monos with calvert shocks. The stock rear frame rails where also moved in. The truck floor was spilt and put back togeather. The way the floor is it moves the shocks even more of a angle then stock. I have read that putting the shocks vertical is going to help it have more control. I was haveing issues with the car at the track and I belive the rear shock is binding. I've seen pictures of cars with the shock in front of the rear and behind. Its looks like I have more room in the front. Was wondering if there is a better place for it to be.
Re: A body cal-trac vertical shock [Re: NoFrills] #2247339
02/04/17 08:26 PM
02/04/17 08:26 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
How is the shock binding? If the new location makes the length shorter, either relocate the lower mount or get shorter shocks.
[image][/image]
Re: A body cal-trac vertical shock [Re: NoFrills] #2247342
02/04/17 08:31 PM
02/04/17 08:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just remember that if you move to the front
of the axle your shocks will need to be stronger
by the percentage of change.. measure from the
front spring eye to the shock mount now then when
you get them mounted in front measure the percentage
of change
wave
Re: A body cal-trac vertical shock [Re: NoFrills] #2247343
02/04/17 08:33 PM
02/04/17 08:33 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would call Calvert, they will be glad to give you advice.
Bill
Re: A body cal-trac vertical shock [Re: NoFrills] #2247347
02/04/17 08:46 PM
02/04/17 08:46 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
The straighter the shock is the better it will work. The less angle the better.
Re: A body cal-trac vertical shock [Re: 1980volare] #2247353
02/04/17 08:54 PM
02/04/17 08:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is true for drag racing... if the shock
is vertical you utilize 100% of the shocks
ability... if the shock is vertical and is
in front of the axle you MIGHT get away with
that shocks ability to control the axle but
I doubt it
wave
Re: A body cal-trac vertical shock [Re: MR_P_BODY] #2247362
02/04/17 09:04 PM
02/04/17 09:04 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
this is what I have
Re: A body cal-trac vertical shock [Re: NoFrills] #2247368
02/04/17 09:14 PM
02/04/17 09:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are those shocks the 5 way or 9 way adjustables..
see if they work on the front... but check the
length first.. you dont want the lower mount hanging
way down
wave
Re: A body cal-trac vertical shock [Re: NoFrills] #2247376
02/04/17 09:25 PM
02/04/17 09:25 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
I put mine in front of the axle and vertical. My car LOVED it. 1.21 60 ft. Viking custom valved D/A shocks
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: A body cal-trac vertical shock [Re: Dave_S] #2247387
02/04/17 09:41 PM
02/04/17 09:41 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
this is from the leaf spring record post
Re: A body cal-trac vertical shock [Re: NoFrills] #2247388
02/04/17 09:42 PM
02/04/17 09:42 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
My current shocks will definatly be to long. Not sure if they are 5 or 9 way.
Re: A body cal-trac vertical shock [Re: NoFrills] #2247757
02/05/17 03:06 PM
02/05/17 03:06 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Can you swap the shock mount plates side to side to use them forward of the rear end? That would make adding mounts to the inside of the frame rail fairly straight forward I would think?
