EFI: Fuel Cell or In Tank #2243895
01/30/17 12:33 PM
01/30/17 12:33 PM
Richmond, Indiana
19swinger70 Offline OP
Richmond, Indiana
Dudes, I am trying to decide between two build options for my current project.
The car: '67 Barracuda Fastback
The Build: Nasty Big Block (440) Street Machine
I started building this 12 years ago. Back then, I cut out the spare tire well, because it was hacked up. My plan back then was to weld in a flat piece, and then install a fuel cell. In 2005, I was going to just run a carb.
Fast forward to 2017, there are easy fuel injection kits, and Spectra tanks with electric fuel pumps. So, I want to go fuel injection now.
Here are my two choices:
Choice#1
Weld in flat trunk floor
After market 16 gallon fuel cell
External EFI fuel pump
Choice#2
Get a new spare tire well and weld it in
Install Spectra Tank with internal EFI fuel pump
From a cost perspective (just counting fuel system - not EFI system) what would you do (given that my trunk floor is already cut out)?
This car is going to be my rough, blunt object - instead of my nice looking cruiser.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244149
01/30/17 07:13 PM
01/30/17 07:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I like having a functional trunk. I'd pop a floor in it and do a factory style tank just for convenience.
- Stu Harmon
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244219
01/30/17 08:54 PM
01/30/17 08:54 PM
IL
furious70 Offline
furious70  Offline
IL
Cell will require more safety work to segregate the trunk from passenger area
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244223
01/30/17 08:57 PM
01/30/17 08:57 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I'm missing the point, its possible? to flat floor it, and? install a cell underneath, with fill tube/etc thru the top, which is the direction I would pursue.
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244232
01/30/17 09:08 PM
01/30/17 09:08 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It's all possible. It's a fastback without a ton of room in the trunk. It'd be cool to go back to the factory way and get an in-tank system like all the late model cars use. My .02.
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244421
01/31/17 12:52 AM
01/31/17 12:52 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
TanksInc tank, done. I don't see the appeal of a cell outside of a pure racecar.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: EFI: Fuel Cell or In Tank [Re: jcc] #2244604
01/31/17 12:31 PM
01/31/17 12:31 PM
Richmond, Indiana
Richmond, Indiana
I'm not asking what is possible - I can build anything. I was asking opinions about cost - given the steps I took 12 years ago, before the EFI options we have today.
Trunk space is not a concern - and I can fab an aluminum barrier to keep the passenger compartment separate. I will mount the battery in the trunk anyway.
I am leaning toward putting a stock tank back in. One of the sticking points that is specific to a '67 is that the factory configuration has only 1 tank strap, and it runs perpendicular to the frame rail. So, this is different than the familiar, '68 on up 2 strap, parallel to the frame style. If I replace the trunk - I'd just put the '68 style in it - but it could be a little more work to make the change.
55 Plymouth Project
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244667
01/31/17 01:58 PM
01/31/17 01:58 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would finish flat flooring the trunk. Next I would fabricate my own under-floor fuel cell with a filler neck going to the factory location. This would be way cheaper than any aftermarket/efi tank. During fabrication you can make your own internal sump or baffles for the fuel pickup. I would run an external in-line EFI pump. I've used them in the past and I like them.
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244692
01/31/17 02:33 PM
01/31/17 02:33 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This aspect of our hobby has been evolving quickly. Fuel systems have come a long way in the last 5 years, especially for EFI conversions.
Gone are the days of intricate baffles, sumps, fuel traps and/or multiple snow mobile style pick-ups in an attempt to get air free fuel to the motor.
Now, you can use a stock tank, cut a hole in the top, stuff in a properly sized Holley Hydromat and plug the access hole with a fuel cell style blocking plate kit. Done, and it will out perform any of the older technology down to the last gallon.
Fuel pumps can either go inside the tank or outside the tank. Simple.
The latest trend is to use PWI controlled fuel pumps with no return. Return style regulators work well too.
In your case, I would put a flat floor in and mount a larger capacity fuel tank under the floor taking advantage of the extra room you have. Added fuel capacity is nice with a hungry big block.
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244737
01/31/17 03:29 PM
01/31/17 03:29 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
If your going to cut out the spare tire well look at using a 1st Gen Mustang tank.
They bolt right in the hole the well leaves in the floor.
You can buy them EFI ready and even with side filler neck.
Re: EFI: Fuel Cell or In Tank [Re: 2734bbl] #2244865
01/31/17 06:57 PM
01/31/17 06:57 PM
Richmond, Indiana
Richmond, Indiana
I'd like to look into this. Can you point me to where to info is on these? I don't know the ford world.
55 Plymouth Project
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244914
01/31/17 08:25 PM
01/31/17 08:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2244916
01/31/17 08:30 PM
01/31/17 08:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I didn't think about those tanks that doubled as the trunk floor.
This site has dimensions:
http://www.autoworksracing.com/gas_tanks1.htm
- Stu Harmon
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2245189
02/01/17 10:24 AM
02/01/17 10:24 AM
the house on the left.
cogen80 Offline
cogen80  Offline
put the proper trunk back in and buy the proper tank with internal pump and be done. be a lot cleaner looking, function like it should and you'l have a trunk you can actually use..
Re: EFI: Fuel Cell or In Tank [Re: feets] #2249146
02/07/17 04:00 PM
02/07/17 04:00 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
This is one example but Ive seen cheaper units.
http://www.mustangstofear.com/page.php?page=parts_catalog&yr=67-68&prod=side-fill_gas_tank
Fits flush in the trunk, side fill for the stock A body neck, angle up in towards the rear so the rear bumper hides most of it and ready to go.
Gets the weight all the way to the rear of the car and higher up than the stock tank and frees up a lot of room under the car.
Re: EFI: Fuel Cell or In Tank [Re: 2734bbl] #2249366
02/07/17 10:37 PM
02/07/17 10:37 PM
IN
ahy Offline
ahy  Offline
IN
Pump in tank is quietest and most durable. It also packages well with current choices available. That would be my suggestion. I like a usable trunk and spare tire when not on the track... but sounds like that is just bonus in your application.
Re: EFI: Fuel Cell or In Tank [Re: 19swinger70] #2251600
02/11/17 02:17 PM
02/11/17 02:17 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I have the pump in the tank (Aeromotive Phantom) which was all that was available before the specific tanks for a-bodies actually came out. It's nice, very quiet, picks up fuel very well too.
I did this to get the tank tucked up instead of spacing it down, and if the pump goes it's easy to change.
Now that the purpose built tank exists, that's a great option.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
