440 Isky Adjustable Rockers #2243232
01/29/17 02:51 AM
01/29/17 02:51 AM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
I plan on using these on my 440 solid cam build! Can someone tell me the correct Isky pushrod set number that would go with these or are there better pushrods to get with this setup?
Re: 440 Isky Adjustable Rockers [Re: JohnnyBeGood] #2243234
01/29/17 02:54 AM
01/29/17 02:54 AM
Portland Oregon
Portland Oregon
Also where can I get these rebuilt here in Portland Oregon or else where?
Re: 440 Isky Adjustable Rockers [Re: JohnnyBeGood] #2243250
01/29/17 03:39 AM
01/29/17 03:39 AM
Washington
madscientist Offline
Washington
Rocker Arm Specialties will rebuild the rockers.
Tom's Performance Machine in Vancouver.
Re: 440 Isky Adjustable Rockers [Re: JohnnyBeGood] #2243262
01/29/17 04:53 AM
01/29/17 04:53 AM
Cab_Burge Online work
Cab_Burge  Online Work
Which version Isky ductile iron rocker arms do you have, early with the welded on harden wear pads or the later ones with no pads? They are different in length on the contact pads shruggy
Re: 440 Isky Adjustable Rockers [Re: JohnnyBeGood] #2243267
01/29/17 05:13 AM
01/29/17 05:13 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Always measure the actual pushrod length required. S/F....Ken M
Re: 440 Isky Adjustable Rockers [Re: JohnnyBeGood] #2243276
01/29/17 09:21 AM
01/29/17 09:21 AM
Australia
P
Project kickin A Offline
P
Australia
I have a set of bb isky rockers. they have a spring and spacer type design between the rockers, stout set up
Re: 440 Isky Adjustable Rockers [Re: JohnnyBeGood] #2243457
01/29/17 05:19 PM
01/29/17 05:19 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Plan on spending about $550 with new shafts and hardware and you may be waiting a long time. I had a set done about 6 years ago and they still look like new.
I would ditch the springs and go with spacers twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 440 Isky Adjustable Rockers [Re: fourgearsavoy] #2243665
01/29/17 10:38 PM
01/29/17 10:38 PM
Washington
Washington
Gus beer
RAS does very nice work.
Re: 440 Isky Adjustable Rockers [Re: madscientist] #2243731
01/30/17 12:46 AM
01/30/17 12:46 AM
Rittman Ohio
Rittman Ohio
Gus beer
I like how they re-direct the oiling to the pushrod cup and the valve spring/stem. It was expensive but these rockers will still be rocking after I'm done rocking drumhit
Gus beer
64 Plymouth Savoy
Dana 60
Re: 440 Isky Adjustable Rockers [Re: JohnnyBeGood] #2243747
01/30/17 01:26 AM
01/30/17 01:26 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The first set of adjustable rockers I bought were Isky's, that was back about in 1970. I don't remember measuring for any length at the time. Just bought the push rods for a solid lifter cam which was a Crower 480 lift/ 300 duration. Over the years I have had many solid lifter cams and different rocker assemblies and always just bought from Jegs what ever push rod was listed for a adjustable solid lifter set up. The only time I did measure for push rod length was when I went to roller rockers. Properly measured up the length and still came up with a in stock length from Jeg's. I would say measure the length and see what Jeg's/ Summit or who ever your choice may be have in stock. If that fails, Manton or Smith Brothers and probably some others can set you up with a quality set.
Re: 440 Isky Adjustable Rockers [Re: JohnnyBeGood] #2244808
01/31/17 05:15 PM
01/31/17 05:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Measure the pushrod length required.
