Re: 440 Isky Adjustable Rockers
[Re: JohnnyBeGood]
#2243250
01/29/17 03:39 AM
01/29/17 03:39 AM
Posts: 4,457 Washington
madscientist
Washington
Also where can I get these rebuilt here in Portland Oregon or else where? Rocker Arm Specialties will rebuild the rockers. Tom's Performance Machine in Vancouver.
[Re: JohnnyBeGood]
#2243457
01/29/17 05:19 PM
01/29/17 05:19 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Plan on spending about $550 with new shafts and hardware and you may be waiting a long time. I had a set done about 6 years ago and they still look like new. I would ditch the springs and go with spacers Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2243665
01/29/17 10:38 PM
01/29/17 10:38 PM
madscientist
Washington
Plan on spending about $550 with new shafts and hardware and you may be waiting a long time. I had a set done about 6 years ago and they still look like new. I would ditch the springs and go with spacers Gus RAS does very nice work.
[Re: madscientist]
#2243731
01/30/17 12:46 AM
01/30/17 12:46 AM
fourgearsavoy
Rittman Ohio
Plan on spending about $550 with new shafts and hardware and you may be waiting a long time. I had a set done about 6 years ago and they still look like new. I would ditch the springs and go with spacers Gus RAS does very nice work. I like how they re-direct the oiling to the pushrod cup and the valve spring/stem. It was expensive but these rockers will still be rocking after I'm done rocking Gus
[Re: JohnnyBeGood]
#2243747
01/30/17 01:26 AM
01/30/17 01:26 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
The first set of adjustable rockers I bought were Isky's, that was back about in 1970. I don't remember measuring for any length at the time. Just bought the push rods for a solid lifter cam which was a Crower 480 lift/ 300 duration. Over the years I have had many solid lifter cams and different rocker assemblies and always just bought from Jegs what ever push rod was listed for a adjustable solid lifter set up. The only time I did measure for push rod length was when I went to roller rockers. Properly measured up the length and still came up with a in stock length from Jeg's. I would say measure the length and see what Jeg's/ Summit or who ever your choice may be have in stock. If that fails, Manton or Smith Brothers and probably some others can set you up with a quality set.
[Re: JohnnyBeGood]
#2244808
01/31/17 05:15 PM
01/31/17 05:15 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
Measure the pushrod length required.
