Mechanical throttle stops #2241027
01/25/17 02:40 PM
01/25/17 02:40 PM
Easton, PA
68DART360 Offline OP
Easton, PA
Anyone use the moroso 65042 positive throttle stop? Any others or can anybody show me how they made their own? Thanks!
Re: Mechanical throttle stops [Re: 68DART360] #2241048
01/25/17 03:32 PM
01/25/17 03:32 PM
tboomer Offline
tboomer  Offline
Good question! We have been talking about an ET Genie to slow the car down for my grandson.
Re: Mechanical throttle stops [Re: tboomer] #2241054
01/25/17 03:44 PM
01/25/17 03:44 PM
Easton, PA
Easton, PA
ET Genie is a little more than I wanted to spend. Like $400 more. A guy I race with has different restrictor plates he changes for the weather conditions
Re: Mechanical throttle stops [Re: 68DART360] #2241060
01/25/17 03:52 PM
01/25/17 03:52 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Had the Moroso, modified it a bit, took 1/2 of the throttle away as well as lowered shift points to make a 12.0 index out of a 11.6 car...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Mechanical throttle stops [Re: 68DART360] #2241063
01/25/17 03:56 PM
01/25/17 03:56 PM
tboomer Offline
tboomer  Offline
Im not comfortable with a rookie in a 10 second car. He needs seat time.
Re: Mechanical throttle stops [Re: 68DART360] #2241073
01/25/17 04:10 PM
01/25/17 04:10 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Starting using one last year.
I was able to slow from 11.20s to 11.50s
72 Plymouth Roadrunner 11.08@123.25
Re: Mechanical throttle stops [Re: OUTLAWD] #2241074
01/25/17 04:10 PM
01/25/17 04:10 PM
Easton, PA
Easton, PA
Thanks for the input. Trying to slow 11.2 car to 11.50 index. Lowered shift points to the level that I shifted from 1st to 2nd and then to third immediately. Did not think it was a good thing for the converter.
Re: Mechanical throttle stops [Re: Roughbird72] #2241076
01/25/17 04:12 PM
01/25/17 04:12 PM
Easton, PA
Easton, PA
bubby440, did you use the moroso one or something else?
Re: Mechanical throttle stops [Re: 68DART360] #2241111
01/25/17 05:18 PM
01/25/17 05:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ted FWIW that's probably the best way. Threw my kid in the dragster with it wowed up a bit but that was still 9.0's. Even with a stock stroke 440 it wasn't easy
Re: Mechanical throttle stops [Re: 68DART360] #2241115
01/25/17 05:20 PM
01/25/17 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is what I made for my 1050 dom...it slips
into the hole at the center and rotates down
over the rear stud to mount the carb.. worked
very good for me
wave
Re: Mechanical throttle stops [Re: 68DART360] #2241133
01/25/17 05:54 PM
01/25/17 05:54 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Lots of ways to slow a car .3
1. Disconnect secondaries
2. Launch in 2nd gear
3. Mechanical stop
4. Pedal it (my preference)
Problem with 1 and 3 was trying to run S/P and S/ST on same day.
Ted, you are talking 1-1/2 seconds, you are going to need something more robust, like a 300-cfm 2bbl on an adapter.
Re: Mechanical throttle stops [Re: cgall] #2241148
01/25/17 06:14 PM
01/25/17 06:14 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have been using a modified version of the Moroso stop for almost 10 years now and have been pretty successful with it. However I changed my throttle cable bracket to a Jegs one so I could use two bolts to mount the stop otherwise it tends to move when only attached to the carb stud.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Mechanical throttle stops [Re: 11secdart] #2241209
01/25/17 08:01 PM
01/25/17 08:01 PM
Easton, PA
Easton, PA
Bill, I need to take a better look at yours in person this year
Re: Mechanical throttle stops [Re: MR_P_BODY] #2241213
01/25/17 08:04 PM
01/25/17 08:04 PM
Easton, PA
Easton, PA
MRpBody, how much to make me one that looks nice
Re: Mechanical throttle stops [Re: 68DART360] #2241224
01/25/17 08:34 PM
01/25/17 08:34 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Sure Jim anytime
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Mechanical throttle stops [Re: 68DART360] #2241295
01/25/17 11:00 PM
01/25/17 11:00 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
The ET Genie is awesome! I use it with CrewChief software and as long as my 60ft prediction is correct, the Genie will put me right on the number every time. On my car I have learned for example that .01 open or closed will add/subtract that time directly to the ET. I also like the fact the with the Genie I am always going "full throttle" so the car is so much more consistent than the throttle arm restricters I used before.
Re: Mechanical throttle stops [Re: 68DART360] #2241657
01/26/17 02:37 PM
01/26/17 02:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you using a 4500 type carb... if you are
I'll give it to ya for shipping cost.. I will
have to make up something for my new set up..
and I dont know if this would work on a 4150
style carb
EDIT
Where I have it set now and a rpm change on
the launch and shift points I went from 9.0
to 10.0 .. I made 8 passes that day and never
varied more than .006 on the day
wave
Re: Mechanical throttle stops [Re: MR_P_BODY] #2241766
01/26/17 05:36 PM
01/26/17 05:36 PM
Easton, PA
Easton, PA
I'm using a 4150 950 HP carb
Re: Mechanical throttle stops [Re: 68DART360] #2241860
01/26/17 08:39 PM
01/26/17 08:39 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
We used the Moroso 65042 stop to slow the Duster from 10.7's to 11.5's (no cage at the time). We had to put an extension on the stop to slow it down enough. It worked great aside from breaking the throttle cable in round one of the first elimination round because the stop stopped the gas pedal from making it all the way to the floor and broke the pedal end of the cable off. We fixed the issue by also putting a stop under the gas pedal. the car was very consistent and we went many bracket rounds with it that way. Now have a cage but still use the stop on occasion for index classes.
Re: Mechanical throttle stops [Re: 68DART360] #2242167
01/27/17 10:52 AM
01/27/17 10:52 AM
Keymar, MD
DusterKid Online content
DusterKid  Online Content
Keymar, MD
To me if you have a cable throttle cable you will need a stop for your gas pedal as it is only a matter of time before the cable breaks. If your throttle is a rod than you will be okay. I have a factory throttle cable on my car and had to add small piece of flat metal between the end of the cable and the carb for it to reach. I made the flat piece about 2 inches longer than needed and drilled extra holes in it so I can shorten the cable thus preventing full throttle to help slow the car down. I haven't gotten to use it yet, and it won't be as precise to dial in for an ET like the bolt and nut, but will help slow the car down a X given amount.
