BB oil dip stick #2239773
01/23/17 01:59 PM
01/23/17 01:59 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Does the 360 oil dip stick fit a BB? Just thought i might be able to reuse my new 360 dip stick.
Re: BB oil dip stick [Re: mopar dave] #2239834
01/23/17 03:45 PM
01/23/17 03:45 PM
Not properly, the crankshaft being higher in the block and the oil pan being flat would render any reading inaccurate tsk
Re: BB oil dip stick [Re: mopar dave] #2239844
01/23/17 04:01 PM
01/23/17 04:01 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Summit has a locking dipstick for 727. It's a rule for as fast as you go.
Re: BB oil dip stick [Re: FastmOp] #2239863
01/23/17 04:41 PM
01/23/17 04:41 PM
Mt Morris Michigan
Mt Morris Michigan
ok, I need an oil dip stick
Re: BB oil dip stick [Re: mopar dave] #2239870
01/23/17 04:55 PM
01/23/17 04:55 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
440 source sells a stock style un-coated one cheap, paint engine color.
DON'T buy the chrome ones. The cheap chrome starts to flake off into the oil when you're checking your oil, driving you crazy thinking that you're generating metal, tearing the engine apart, losing sleep, etc. Just say no.
Re: BB oil dip stick [Re: mopar dave] #2239940
01/23/17 07:06 PM
01/23/17 07:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Depending on the pan the stock one may not work. Mine hit the bottom of the pan before it hit oil. 7 qts in a 10 qt pan.
Doug
Re: BB oil dip stick [Re: dvw] #2239965
01/23/17 08:00 PM
01/23/17 08:00 PM
Mt Morris Michigan
Mt Morris Michigan
Im using a 7qt moroso pan.
Re: BB oil dip stick [Re: mopar dave] #2239974
01/23/17 08:13 PM
01/23/17 08:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Regardless of the pan capacity, the "FULL" level should be the same.
Since the big block has a long skirt below the crank centerline, the pan rail is lower and the tube mounts lower on the centerline, so the BB and SB dipsticks wont interchange.
