Re: BB oil dip stick
[Re: mopar dave]
#2239870
01/23/17 04:55 PM
01/23/17 04:55 PM
Posts: 5,166 CT
GTX MATT
CT
440 source sells a stock style un-coated one cheap, paint engine color.
DON'T buy the chrome ones. The cheap chrome starts to flake off into the oil when you're checking your oil, driving you crazy thinking that you're generating metal, tearing the engine apart, losing sleep, etc. Just say no.
[Re: mopar dave]
#2239974
01/23/17 08:13 PM
01/23/17 08:13 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Regardless of the pan capacity, the "FULL" level should be the same.
Since the big block has a long skirt below the crank centerline, the pan rail is lower and the tube mounts lower on the centerline, so the BB and SB dipsticks wont interchange.
