Page 4 of 6 1 2 3 4 5 6
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236982
01/18/17 10:02 PM
01/18/17 10:02 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
I ran a roots blower before switching over to an F2 Procharger 6 yrs ago. The problems then was there was no "kit" for big blocks. Called Procharger and they directed you to Bob/Terry Woods at The Supercharger Store. The mopar kit consists of a sbc kit which uses the mounting bracket with a custom adapter for the mopar alum water pump.
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2237022
01/18/17 11:32 PM
01/18/17 11:32 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
If I recall big time sells a kit for bbm. His car gets it the last time I saw it run. I believe he uses the SBC kit for it ?
Re: Why so few Procharger Mopar builds? [Re: SpareParts] #2237052
01/19/17 12:48 AM
01/19/17 12:48 AM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By SpareParts
Originally Posted By Crizila
Originally Posted By FastmOp
Intake air temp
Don't monitor it. I do run race gas (110) and spray ( Snow system ).
Gotcha, was wondering how things do with the hot air setup you have. Makes plumbing easy tho
Actually, I don't use the intake system in the pic. I run my filter directly on the intake horn of the compressor. Without inner fender panels, I have enough air circulation under the hood that it doesn't make any difference where I pick up intake air.
Fastest 300
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2237105
01/19/17 01:53 AM
01/19/17 01:53 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Oh, I didn't even pay attention to the filter, I meant the lack of an intercooler
Re: Why so few Procharger Mopar builds? [Re: SpareParts] #2237198
01/19/17 11:57 AM
01/19/17 11:57 AM
Az
Crizila Offline
Crizila  Offline
Az
Intercooler for sure if this were a street application - pump gas.
Fastest 300
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2237285
01/19/17 03:09 PM
01/19/17 03:09 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Has anyone tried or know anybody using the FITECH 1200 blow through FI setup? This might be an option if I keep it in the 900 hp range.
Re: Why so few Procharger Mopar builds? [Re: 70dusterjohn] #2237324
01/19/17 04:50 PM
01/19/17 04:50 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Bigtime is a procharger dealer, so he can get you any kit you want. My friend bought his there and got a good deal. He runs a crank mounted f2 on his dart now, hasn't had the sideslinger in quite a while.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Why so few Procharger Mopar builds? [Re: 1967dartgt] #2237369
01/19/17 06:13 PM
01/19/17 06:13 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
There is a local guy here in the area where I live, who has a '69 Dart street/strip car with a 340 based 416 c.i. STROKER small block. He is using a Procharger on his car (not sure which model he has), but he has water injection as well.
Just his blower setup ran about $8-9k I heard once...and his car is running 9.80's in the quarter mile...FWIW. shruggy
Plymouth Makes It!
Re: Why so few Procharger Mopar builds? [Re: RoadRunnerLuva] #2237391
01/19/17 06:50 PM
01/19/17 06:50 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I'm surprised that bigtimeauto hasn't chimed in yet.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2237428
01/19/17 07:32 PM
01/19/17 07:32 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
He doesn't come on here anymore.
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2237460
01/19/17 08:17 PM
01/19/17 08:17 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Here is my old procharged hemi at 8:06 of the video
https://www.youtube.com/watch?v=ADgmsK2zs44
Re: Why so few Procharger Mopar builds? [Re: The Shadow] #2237473
01/19/17 08:40 PM
01/19/17 08:40 PM
Nebraska
Nebraska
Love it!!!!!!
Re: Why so few Procharger Mopar builds? [Re: The Shadow] #2237502
01/19/17 09:10 PM
01/19/17 09:10 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Beautiful car.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2237553
01/19/17 10:52 PM
01/19/17 10:52 PM
Shannonville, Ont
Shannonville, Ont
Mine is set up similar to Crizila's. A F2 on stock stroke 440, 950 blow thru , Car runs 9.40@145mph on 15lbs boost pulling 10 degree timing.
Re: Why so few Procharger Mopar builds? [Re: The Shadow] #2237564
01/19/17 11:06 PM
01/19/17 11:06 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
That 'runner is awesome!...by old do you mean you have since sold it?
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2237567
01/19/17 11:08 PM
01/19/17 11:08 PM
Nebraska
Nebraska
Blown 68 R/t, do you mind me asking what heads and cam specs? You are pretty close to where I want to be with this build. Thanks
Re: Why so few Procharger Mopar builds? [Re: RTSrunner] #2237570
01/19/17 11:11 PM
01/19/17 11:11 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
The procharged hemi was mine. Johnny had the body built for it
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2237571
01/19/17 11:13 PM
01/19/17 11:13 PM
Shannonville, Ont
Shannonville, Ont
Sure thing, heads are Sidewinders from Todd @ Marsh Performance heads were ported by Larry Smith. Cam is a Comp solid roller 256/264 631/631 114lsa. If I could figure out how to post pics/vids I would.
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2237613
01/20/17 12:09 AM
01/20/17 12:09 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Is there anyone making or selling actual kits for sb LA engines? Anyone know what they cost?
Re: Why so few Procharger Mopar builds? [Re: The Shadow] #2237658
01/20/17 12:58 AM
01/20/17 12:58 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Nice job sir, that car is awesome.
