Re: Electrical connectors
[Re: ahy]
#2236385
01/17/17 11:14 PM
01/17/17 11:14 PM
RapidRobert
Agreed, the terminals/connections are always the weak points in a circuit & you want em cleaned/soldered/crimped/shrink wrapped as needed the best you know how for a minimal voltage drop & each voltage drop adds up.
[Re: Jaymar]
#2236390
01/17/17 11:19 PM
01/17/17 11:19 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If originality is not a concern, a cannon plug is hard to beat.
[Re: Jaymar]
#2236421
01/17/17 11:50 PM
01/17/17 11:50 PM
Supercuda
About to go away
About to go away
up yours
Guys will drop $10k+ for a crate engine, but won't spend a few dollars extra on quality electrical connections.
Surplus sales are key.
[Re: Jaymar]
#2236585
01/18/17 10:23 AM
01/18/17 10:23 AM
Supercuda
About to go away
About to go away
up yours
Yeah, I think the interior connections are probably good as is with a cleaning and a coat of dielectric, but exterior and especially underhood, no.
At least weatherpack them. But the OEM bulkhead connection? Cannon plug it.
[Re: Jaymar]
#2236592
01/18/17 11:00 AM
01/18/17 11:00 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
The entire aerospace industry is still using cannon plugs. Not just the military.
**Photobucket sucks**
[Re: Jaymar]
#2237188
01/19/17 11:34 AM
01/19/17 11:34 AM
Supercuda
About to go away
About to go away
up yours
Details? Like PN, with that I can probably find a spec sheet.
[Re: Skeptic]
#2240168
01/24/17 12:24 AM
01/24/17 12:24 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
This is what I'm using for the bulkhead connector. I used to have an '87 International semi-truck project and it uses the same connector, still working fine after 30+ years. Much less expensive than Cannon, too. (Weatherpack type contacts/seals). Those are common on e-bay, I have one for my Barracuda. I plan on using it when I go with the EFI. There are different configurations for number of wires and gauges, so figure what your needs are and shop carefully. Take a look here: https://www.diyautotune.com/product/weather-pack-22-position-bulkhead-connector-kit/
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: Jaymar]
#2240379
01/24/17 01:36 PM
01/24/17 01:36 PM
Posts: 1,822 Colorado
denfireguy
Colorado
DIY Auto has very fast shipping as well.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
