Electrical connectors #2236006
01/17/17 01:45 PM
01/17/17 01:45 PM
Jersey shore
Jaymar Offline OP
Jaymar  Offline OP
Jersey shore
Hello, I need a little help . Does anyone know where I can get the electrical connectors on the dash harness that connect to the ignition switch and the turn signal switch , there the white ones and its for a 72 road runner.
Re: Electrical connectors [Re: Jaymar] #2236007
01/17/17 01:47 PM
01/17/17 01:47 PM
Re: Electrical connectors [Re: RapidRobert] #2236369
01/17/17 11:01 PM
01/17/17 11:01 PM
IN
ahy Offline
ahy  Offline
IN
Year One should have the whole harness.
Those connectors, even newer re-production, are not particularly robust. I have by-passed the connector block with individual connections for the heavily loaded wires on mine even with re-pop harness.
Re: Electrical connectors [Re: ahy] #2236385
01/17/17 11:14 PM
01/17/17 11:14 PM
Agreed, the terminals/connections are always the weak points in a circuit & you want em cleaned/soldered/crimped/shrink wrapped as needed the best you know how for a minimal voltage drop & each voltage drop adds up.
Re: Electrical connectors [Re: Jaymar] #2236390
01/17/17 11:19 PM
01/17/17 11:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If originality is not a concern, a cannon plug is hard to beat.
Don't be the exception.
Re: Electrical connectors [Re: Jaymar] #2236407
01/17/17 11:37 PM
01/17/17 11:37 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
The military used them for decades (and probably still are using them)... But they are very expensive. AMP or Molex connectors with properly sized contacts will do fine.
(Also I ran all the high-current circuits of my Dart through relays, so the steering column wiring harness no longer has to have huge contacts).
Re: Electrical connectors [Re: Jaymar] #2236421
01/17/17 11:50 PM
01/17/17 11:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Guys will drop $10k+ for a crate engine, but won't spend a few dollars extra on quality electrical connections.
Surplus sales are key.
Re: Electrical connectors [Re: Jaymar] #2236471
01/18/17 01:04 AM
01/18/17 01:04 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
It's more than "a few" dollars, and I'm not recommending a twist-n-tape instead of a proper connector that will do the job required of it. No need to overspend... obviously something in the engine compartment carrying tens of amps, exposed to heat and road splash is more critical than the dome light connector above the headliner whistling
When buying surplus Cannon connectors, the hard part usually is finding a mating pair. I have a box full of plugs with no sockets and vice versa.
Re: Electrical connectors [Re: Jaymar] #2236585
01/18/17 10:23 AM
01/18/17 10:23 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yeah, I think the interior connections are probably good as is with a cleaning and a coat of dielectric, but exterior and especially underhood, no.
At least weatherpack them. But the OEM bulkhead connection? Cannon plug it.
Re: Electrical connectors [Re: Jaymar] #2236592
01/18/17 11:00 AM
01/18/17 11:00 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
The entire aerospace industry is still using cannon plugs. Not just the military.
**Photobucket sucks**
Re: Electrical connectors [Re: Jaymar] #2236649
01/18/17 01:13 PM
01/18/17 01:13 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
I may have a used ignition block connector for your car in with my wiring harness stuff. Would it be possible for you to shoot me a pic? I know I have a bunch of in dash white connectors only with wire stubs. I just can't remember if it's for the ignition switch.
Re: Electrical connectors [Re: Supercuda] #2237069
01/19/17 01:02 AM
01/19/17 01:02 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
This is what I'm using for the bulkhead connector. I used to have an '87 International semi-truck project and it uses the same connector, still working fine after 30+ years. Much less expensive than Cannon, too.
(Weatherpack type contacts/seals).
Re: Electrical connectors [Re: Jaymar] #2237188
01/19/17 11:34 AM
01/19/17 11:34 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Details? Like PN, with that I can probably find a spec sheet.
Re: Electrical connectors [Re: DrCharles] #2237217
01/19/17 12:46 PM
01/19/17 12:46 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Those are common on e-bay, I have one for my Barracuda. I plan on using it when I go with the EFI. There are different configurations for number of wires and gauges, so figure what your needs are and shop carefully. twocents
Re: Electrical connectors [Re: Skeptic] #2240168
01/24/17 12:24 AM
01/24/17 12:24 AM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
Take a look here:
https://www.diyautotune.com/product/weather-pack-22-position-bulkhead-connector-kit/
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Electrical connectors [Re: Jaymar] #2240192
01/24/17 12:56 AM
01/24/17 12:56 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That is not a bad price.
Re: Electrical connectors [Re: Jaymar] #2240246
01/24/17 02:22 AM
01/24/17 02:22 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I may even have gotten mine from that site... just had to make a plate to install over the original bulkhead connector opening up
Re: Electrical connectors [Re: Jaymar] #2240379
01/24/17 01:36 PM
01/24/17 01:36 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
DIY Auto has very fast shipping as well.
