Page 3 of 3 1 2 3
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235809
01/17/17 01:59 AM
01/17/17 01:59 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
Andy, is that drive something that you build?
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235922
01/17/17 11:25 AM
01/17/17 11:25 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Here is a post I made a few years ago about my 440 source Dist not clearing my IndyEZ heads. It was bad enough that the Dist cap wouldn't go on. I ended up buying a Firecore Dist and it fit great with no grinding etc. let's see if the link will work
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/932448/1.html
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 511 combo victor head distributor issue [Re: mopar65] #2235925
01/17/17 11:34 AM
01/17/17 11:34 AM
mopar65 Offline
mopar65  Offline
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235926
01/17/17 11:36 AM
01/17/17 11:36 AM
mopar65 Offline
mopar65  Offline
Sorry I used my phone to post the picture and had to crop the pic a bit to get it to fit. But the 440 Dist is on the right and the Firecore Dist is on the left. Hope this might help you
Re: 511 combo victor head distributor issue [Re: mopar65] #2235980
01/17/17 01:14 PM
01/17/17 01:14 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
It doesn't look like I have to grind a lot off that head. Not sure if theres water at that corner or not thou. I will also get a price on a firecore today from Don at FBO as I need to call about the rockers on order. thanks
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235982
01/17/17 01:16 PM
01/17/17 01:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd call Edelbrock and ask about the coolant passages. I ground my -1 , no big deal. Why would anybody build a bolt on head casting that doesn't fit ordinary ditributors is beyond me.
Doug
Re: 511 combo victor head distributor issue [Re: dvw] #2236010
01/17/17 01:52 PM
01/17/17 01:52 PM
Mt Morris Michigan
Mt Morris Michigan
Called edelbrock, they said not to grind on the head. Head not intended to run with a vac advance dist. said any non vac dist. will fit. gonna have to sell this pertronix. thanks guys
Re: 511 combo victor head distributor issue [Re: wyldebill] #2236022
01/17/17 02:09 PM
01/17/17 02:09 PM
AndyF Offline
AndyF  Offline
The belt drive distributor is a bolt on from Jesel (as long as you have the Jesel belt drive setup that is)
I make the water pump spacers and the TDC pointer and a few parts like that but the Jesel stuff fits right out of the box.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2236122
01/17/17 04:36 PM
01/17/17 04:36 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
DOn is NOT an authorized dealer. Call me direct @ 216-224-3667. Thanks.. 199 and shipping..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 511 combo victor head distributor issue [Re: sunroofgtx] #2236145
01/17/17 05:17 PM
01/17/17 05:17 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah, spoke with him earlier. As of now looks like these are my choices for dist, msd, firecore, Daytona sensors, or another FBO brand simular to factory.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2237097
01/19/17 01:41 AM
01/19/17 01:41 AM
CDoering Offline
CDoering  Offline
I have victor heads on a 400 block and the MSD billet distributor clears the head enough for me to rotate it. It does not have enough room to rotate 360 degrees due to the cap bolts. I will have to notch the valve cover slightly though.
I can take a picture tomorrow if anyone would like to see it.
Re: 511 combo victor head distributor issue [Re: CDoering] #2237200
01/19/17 12:00 PM
01/19/17 12:00 PM
Mt Morris Michigan
Mt Morris Michigan
what valve covers you using? a pic would be nice.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2237690
01/20/17 01:50 AM
01/20/17 01:50 AM
CDoering Offline
CDoering  Offline
This is the only picture I have at the moment. It is looking down from the top to show the space between the head and the distributor.
I'm using the Mopar Performance aluminum valve covers and they will not clear the distributor. I still need to clearance them.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2237792
01/20/17 12:06 PM
01/20/17 12:06 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
What I did not like about using a cast valve cover was you had to make sure it was as far up as it would go so it wouldn't hit the rockers or cause any issue there with movement and limited contact sealing the upper edge.
Re: 511 combo victor head distributor issue [Re: CDoering] #2237827
01/20/17 01:02 PM
01/20/17 01:02 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for the pic. Looks like the MSD doesn't fit too bad. At the moment I'm looking at another Pertronix non vac or FBO's Daytona Sensors non vac. There was a new MSD in the for sale section I may take another look at.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2240015
01/23/17 09:04 PM
01/23/17 09:04 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Re: 511 combo victor head distributor issue [Re: mopar dave] #2240017
01/23/17 09:07 PM
01/23/17 09:07 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Re: 511 combo victor head distributor issue [Re: sunroofgtx] #2240033
01/23/17 09:35 PM
01/23/17 09:35 PM
Mt Morris Michigan
Mt Morris Michigan
Look like they fit real nice, but how is the quality now days. Im a little apprehensive after reading some complaints about issues such as reluctor wheels being chewed up. Have all the issues with reliabilty been taken care of? Thanks for the pics of comparison.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2240039
01/23/17 09:41 PM
01/23/17 09:41 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Good to go.. It's been two years now..
Page 3 of 3 1 2 3
