Re: Why so few Procharger Mopar builds?
[Re: mshred]
#2237678
01/20/17 01:36 AM
01/20/17 01:36 AM
Posts: 7,506 Az
Crizila
Az
Is there anyone making or selling actual kits for sb LA engines? Anyone know what they cost? LA and Magnum kits are basically the same. About $3K for mine and it was a bolt on - not including the "Snow" water injection system ( another $500). From the SuperCharger store.
Fastest 300
[Re: The Shadow]
#2237737
01/20/17 04:29 AM
01/20/17 04:29 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
That 'runner is awesome!...by old do you mean you have since sold it? The procharged hemi was mine. Johnny had the body built for it I see,it made a cool package.A friend of mine moved from here(Pittsburgh Pennsylvania) to Australia about 25 years or so back.He sold off his '73 'cuda before he left and I bought his parts stash & the cars original engine/trans.Looks like he should have brought it with him! It was originally a 340-4 speed gunmetal gray car,but had been painted burgundy and had a 440 auto swapped in.
[Re: Blown 68 R/T]
#2237864
01/20/17 01:54 PM
01/20/17 01:54 PM
Posts: 1,705 Nebraska
70VcodeCoronetRT
Nebraska
Mine is set up similar to Crizila's. A F2 on stock stroke 440, 950 blow thru , Car runs 9.40@145mph on 15lbs boost pulling 10 degree timing. If it's ok, when I get closer. I might be picking your brain as far as setup. Just want to make sure I'm safe with timing, fuel, ext Thanks
[Re: 70VcodeCoronetRT]
#2257031
02/21/17 06:41 AM
02/21/17 06:41 AM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Because turbos are cheaper and make more power.
The route I'm about to take on a few cars sitting around the yard. ;-)
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: 1mean340]
#2404705
11/16/17 11:46 PM
11/16/17 11:46 PM
Prochargedmopar
Granbury TX
I'm working on a procharged 340 project myself. It is getting close to completion but the holidays set my machinist back some time wise.
My build is using a D1SC with cheapo front mount intercooler. I have been doing it on a budget (whatever that means, for a forced induction build) so I welded up my own piping and found what may or may not have been an incomplete SDCE bracket that I am heavily modifying to make my own pulley setup with.
the blower is feeding the following 69 340 block, hughes main girdle/studs, factory forged crank, Eagle H beam rods, forged pistons, ported W2 econo heads, E85 fed via aeromotive A1000 fuel system and FItech 1200 fuel injection, solid roller cam
What really sucks about this build is not being able to find brackets/pulleys for cheap. I sourced a billet SDCE one piece crank pulley/blower pulley for 300 something and then the work I have to do to make the bracket work.
Honestly, I think TURBO would have been a MUCH better and probably easier way to go. I already had the procharger though. I considered a single turbo, and I know I am quirky for this but I can't get over a muscle car having a tight overlap turbo cam and all the exhaust coming out one pipe. It's just nowhere near as cool as a big, choppy cam thumping out unobstructed dual exhaust.
Whether the sound is going to be worth the power loss of the blower, added stress on the crank/mains or potential belt slip issues- I don't know.
I am hoping to make around 700fwhp with this setup and pray that it stays together.
One of the biggest issues I see with building up MOPARS for forced induction is that many of the stock blocks can't handle the power that good head flow and boost can make, and when you start getting into aftermarket Mopar blocks the prices are so crazy that who has money left for forced induction as well? If you're a late model GM guy, you can go out and find a $500 5.3 truck motor, spend a few grand building it and make 1000hp with a cheap turbo setup. You could probably do the whole build for the cost of a good Mopar block and machine work.
At least this seems like the case with the small blocks. I know SCDE and a few other guys were pushing factory big block engine blocks way harder (well over 1000hp). For what I ended up sinking into this small block I think I really made a mistake in not trying to do a big block instead. How is your procharger build coming along? I bought a p600b kit with intercooler and fuel system off SDCE back in the late 98-99’. Hah, cant even remember now. I will be putting the blower on my current build but just for fun and funny looks also adding the 78/75 billet turbo I got from VsRacing. Ditching the intercooler and going e85 this time around. Just got my girdle and sent off the carb to Eric for mods. Crank will be back in a week or so then I can mock up to see how much milling needs to be done.
[Re: mshred]
#2404739
11/17/17 12:26 AM
11/17/17 12:26 AM
Prochargedmopar
Granbury TX
Is there anyone making or selling actual kits for sb LA engines? Anyone know what they cost? Small and Big blocks since 1995. http://www.sd-concepts.com/pages/cfHome.cfmWhere I bought mine. They Have had a few Articles printed in mopar mags over the years.
[Re: CTD5.9]
#2534626
08/11/18 04:11 PM
08/11/18 04:11 PM
Posts: 4,071 Mo.
racerx
Mo.
[Re: Prochargedmopar]
#2535568
08/13/18 12:16 PM
08/13/18 12:16 PM
Posts: 8,165 Left Coast
BobR
Left Coast
The route I'm about to take on a few cars sitting around the yard. ;-) That about covers it. My max effort BAE/Procharger/Methanol Outlaw 10.5 car ran 190 MPH at 2800 lbs 1/8th mile. Same car, same motor but with twin turbos has been 209.46 at 3000 pounds 1/8th mile.
[Re: The Shadow]
#2537288
08/16/18 05:39 PM
08/16/18 05:39 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
That 'runner is awesome!...by old do you mean you have since sold it? The procharged hemi was mine. Johnny had the body built for it Shadow... You Build an Awesome intake too!!! I built my own brackets too Made them out of plywood as a mock up and cut the from aluminum
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
#2537682
08/17/18 03:14 PM
08/17/18 03:14 PM
Posts: 2,578 sweden
1Fast340
sweden
I prefer to see and hear my 340 getting screwed. Just a preference.
[Re: 1Fast340]
#2537720
08/17/18 04:25 PM
08/17/18 04:25 PM
Posts: 1,073 oregon
greendart408
oregon
I have a w8, f2 deal. Have only made four 1/8mile shakedown passes. E85, Csu. It’s not all that happy yet. Hard to get it dialed when as of the last couple yrs I only go once a yr. My rate it will take a few more yrs to get it dialed in. Haven’t taken the time to figure out pics or care to, or I would show you guys. I made everything.....
#2537855
08/17/18 09:11 PM
08/17/18 09:11 PM
Posts: 4,209 New York
polyspheric
New York
Blower vs. NA: as long as the primary is big enough (sized for the boosted power, not the engine size or NA power) the length and equal or not matters much less, and saves $$, the chamber is always swept clean by fresh charge (not true with most turbos, which are extremely sensitive to high backpressure vs. boost pressure ratio).
Buying a Procharger: unless you get it from Scott or another trusted source, assume the brackets are too thin, and do what's needed. Many pictures, diagrams of blower brackets would cause a mechanical engineer to cry: metal and holes in the wrong places. Not an expert, but give me a good .jpg of the bracket and how it attaches, and I'll tell you if I see something wrong. Remember, "too thin" isn't the only error but it's common, and sometimes fixable with a simple 1/4" thick doubler plate (even a length of angle) bolted through the bracket assisting the stressed areas. Trust me, many people (who would never offer themselves as engineers) can intuitively "know" where the bracket will bend!
Boffin Emeritus
[Re: polyspheric]
#2538344
08/19/18 12:34 AM
08/19/18 12:34 AM
Posts: 4,255 Canada
WO23Coronet
Canada
Buying a Procharger: unless you get it from Scott or another trusted source, assume the brackets are too thin, and do what's needed. Many pictures, diagrams of blower brackets would cause a mechanical engineer to cry: metal and holes in the wrong places. Not an expert, but give me a good .jpg of the bracket and how it attaches, and I'll tell you if I see something wrong. Remember, "too thin" isn't the only error but it's common, and sometimes fixable with a simple 1/4" thick doubler plate (even a length of angle) bolted through the bracket assisting the stressed areas. Trust me, many people (who would never offer themselves as engineers) can intuitively "know" where the bracket will bend! Are you reffering to the intake runners or exhaust primaries?
