Re: Trans Brakes???
[Re: justinp61]
#2231221
01/09/17 11:49 PM
01/09/17 11:49 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I ran a griner for a few years. Awesome Brake but its a button reverser. Its not that big of deal to get used to especially if the brake button is on the shifter
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Trans Brakes???
[Re: rickraw]
#2231309
01/10/17 01:15 AM
01/10/17 01:15 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
As I said before, u can wire in a switch so u don't have to hold the button in. Very simple. I thought the same switch that activated the brake activates reverse when in the neutral position. Please pardon my ignorance on these as I've never owned one.
Re: Trans Brakes???
[Re: justinp61]
#2231313
01/10/17 01:17 AM
01/10/17 01:17 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Pushing the button for reverse becomes no big deal after a little use.
If you bottom bulb race a fast transbrake is not what I would suggest.
"Just a Bracket car dressed up like a streetcar"
Re: Trans Brakes???
[Re: justinp61]
#2231529
01/10/17 12:39 PM
01/10/17 12:39 PM
Posts: 485 Central California
MoParFish
Central California
I run a A&A LBA VB with Brake. Sets solid at idle and super fast, almost too fast for bottom bulbin' IMHO even in my 3780lb sled. Great for pro tree. Tried to slow it down with a Just-in-Time long throw button and learned quick, there is no magic wand, you still gotta pay attention to cut good lights Also like others have said, I just wired in a toggle switch in near the shifter for reverse. Throw shifter in R or N, flip switch and back up all day long. Pull shifter in to 1st without flipping switch off?? no biggie, it will let you know as car won't move 'til you flip it off. The A&A valve body has been great but, purchased before John Cope came out with his, otherwise would have seriously considered it as well. Also, haven't footbraked it since installing transbrake,,,more fun leaving matted with the button ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
Re: Trans Brakes???
[Re: justinp61]
#2231538
01/10/17 12:48 PM
01/10/17 12:48 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I have a Turbo Action pro brake in my 727. It has no LBA and doesn't require you to push the button for reverse. I think the TA is one of, if not the only pro brake that doesn't require the button to be pushed for reverse.
Re: Trans Brakes???
[Re: MoParFish]
#2231544
01/10/17 12:53 PM
01/10/17 12:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hook up a micro switch so the switch hits the shifter arm when you put it in reverse.. like a lot of aftermarket shifters use for a neutral safety switch ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Trans Brakes???
[Re: an8sec70cuda]
#2231571
01/10/17 01:27 PM
01/10/17 01:27 PM
MR_P_BODY
I have a Turbo Action pro brake in my 727. It has no LBA and doesn't require you to push the button for reverse. I think the TA is one of, if not the only pro brake that doesn't require the button to be pushed for reverse. I think the button deal is for a brake that has the LBA.. I have the T/A brake also.. no LBA and no button for reverse ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Trans Brakes???
[Re: MR_P_BODY]
#2231576
01/10/17 01:34 PM
01/10/17 01:34 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
If you still have the factory 3 prong neutral switch the outer 2 polls are for activating the reverse lights. so if you power up one side and the other to the trans brake terminal as soon as you put into reverse it activates brake no need for another button or switch.
JAKES AUTOMOTIVE
Re: Trans Brakes???
[Re: justinp61]
#2231766
01/10/17 06:22 PM
01/10/17 06:22 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
All 3 cars use Tranzact brake ..one was bought back in 1993...All 3 trans are 904s...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Trans Brakes???
[Re: justinp61]
#2231921
01/10/17 10:49 PM
01/10/17 10:49 PM
dartman366
Mt. Vernon, Ohio
Has anyone ran Copes new brake? I bought one for the new tranny, I have not tried it yet but it's a nice looking and designed unit, it is a button reverse transbrake valve body with lba.
Re: Trans Brakes???
[Re: dartman366]
#2231923
01/10/17 10:53 PM
01/10/17 10:53 PM
dartman366
Mt. Vernon, Ohio
sorry forgot to add the pic
