Trans Brakes??? #2231205
01/09/17 11:35 PM
01/09/17 11:35 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I was considering building a 904 to replace my 727 and buy a new converter but I've decided to send my converter to Kenny ford at PTC to see if he can help it. So instead of building a new transmission and buy a new converter I'm thinking about putting a trans brake in my 727.
This is a street/strip deal so I really don't want to hold a button for reverse and would also like to have lba.
Who's TB valve bodies do you guys recommend?
Re: Trans Brakes??? [Re: justinp61] #2231211
01/09/17 11:40 PM
01/09/17 11:40 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I like transzact. It worked great. I just wired in a switch so u don't have to hold the button in for rev.
Re: Trans Brakes??? [Re: justinp61] #2231214
01/09/17 11:45 PM
01/09/17 11:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
TranZact is lightning fast but needs the button pushed for reverse
Re: Trans Brakes??? [Re: justinp61] #2231221
01/09/17 11:49 PM
01/09/17 11:49 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I ran a griner for a few years. Awesome Brake but its a button reverser. Its not that big of deal to get used to especially if the brake button is on the shifter
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Trans Brakes??? [Re: justinp61] #2231287
01/10/17 12:59 AM
01/10/17 12:59 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I run an A&A LBA brake - no issues but has a button reverse. CRT has a new billet brake that looks well designed. I'm not sure if it has a button reverse but if I had to do it again is what I would buy. Especially with the first and second gear leave options.
I also have a brake button on my shifter. It's a pain backing up one handed with manual steering but hey - it's a race car smile
Re: Trans Brakes??? [Re: justinp61] #2231295
01/10/17 01:03 AM
01/10/17 01:03 AM
W. Kentucky
W. Kentucky
I drive this car quiet a bit is why I was wanting to avoid a button.
Re: Trans Brakes??? [Re: justinp61] #2231299
01/10/17 01:09 AM
01/10/17 01:09 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
As I said before, u can wire in a switch so u don't have to hold the button in. Very simple.
Re: Trans Brakes??? [Re: rickraw] #2231309
01/10/17 01:15 AM
01/10/17 01:15 AM
W. Kentucky
W. Kentucky
I thought the same switch that activated the brake activates reverse when in the neutral position. Please pardon my ignorance on these as I've never owned one.
Re: Trans Brakes??? [Re: justinp61] #2231313
01/10/17 01:17 AM
01/10/17 01:17 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Pushing the button for reverse becomes no big deal after a little use.
If you bottom bulb race a fast transbrake is not what I would suggest.
"Just a Bracket car dressed up like a streetcar"
Re: Trans Brakes??? [Re: justinp61] #2231407
01/10/17 03:40 AM
01/10/17 03:40 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
The button having to he held isn't to big a deal, on the covertor though you may need it beefed up with an anti balloon plate if your going to a transbrake. I have a Protrans brake and it requires the button push, most with the LBA do.
Re: Trans Brakes??? [Re: justinp61] #2231529
01/10/17 12:39 PM
01/10/17 12:39 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I run a A&A LBA VB with Brake. Sets solid at idle and super fast, almost too fast for bottom bulbin' IMHO even in my 3780lb sled. Great for pro tree. Tried to slow it down with a Just-in-Time long throw button and learned quick, there is no magic wand, you still gotta pay attention to cut good lights sleep whistling
Also like others have said, I just wired in a toggle switch in near the shifter for reverse. Throw shifter in R or N, flip switch and back up all day long. Pull shifter in to 1st without flipping switch off?? no biggie, it will let you know as car won't move 'til you flip it off.
The A&A valve body has been great but, purchased before John Cope came out with his, otherwise would have seriously considered it as well. Also, haven't footbraked it since installing transbrake,,,more fun leaving matted with the button twocents thumbs
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Trans Brakes??? [Re: justinp61] #2231538
01/10/17 12:48 PM
01/10/17 12:48 PM
an8sec70cuda Offline
I have a Turbo Action pro brake in my 727. It has no LBA and doesn't require you to push the button for reverse.
I think the TA is one of, if not the only pro brake that doesn't require the button to be pushed for reverse.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Trans Brakes??? [Re: MoParFish] #2231544
01/10/17 12:53 PM
01/10/17 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hook up a micro switch so the switch hits the
shifter arm when you put it in reverse.. like
a lot of aftermarket shifters use for a neutral
safety switch
wave
Re: Trans Brakes??? [Re: justinp61] #2231564
01/10/17 01:18 PM
01/10/17 01:18 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I have a tranz-act one in my 727, but have never used it. It isn't even wired up.
eBay-cdwmotorsports
Re: Trans Brakes??? [Re: an8sec70cuda] #2231571
01/10/17 01:27 PM
01/10/17 01:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think the button deal is for a brake that has the
LBA.. I have the T/A brake also.. no LBA and no button
for reverse
wave
Re: Trans Brakes??? [Re: MR_P_BODY] #2231576
01/10/17 01:34 PM
01/10/17 01:34 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
If you still have the factory 3 prong neutral switch the outer 2 polls are for activating the reverse lights. so if you power up one side and the other to the trans brake terminal as soon as you put into reverse it activates brake no need for another button or switch.
JAKES AUTOMOTIVE
Re: Trans Brakes??? [Re: justinp61] #2231766
01/10/17 06:22 PM
01/10/17 06:22 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
All 3 cars use Tranzact brake ..one was bought back in 1993...All 3 trans are 904s...
Tony
70 AARCuda Vitamin C
Re: Trans Brakes??? [Re: justinp61] #2231801
01/10/17 07:18 PM
01/10/17 07:18 PM
W. Kentucky
W. Kentucky
Has anyone ran Copes new brake?
Re: Trans Brakes??? [Re: justinp61] #2231921
01/10/17 10:49 PM
01/10/17 10:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I bought one for the new tranny, I have not tried it yet but it's a nice looking and designed unit, it is a button reverse transbrake valve body with lba.
Re: Trans Brakes??? [Re: dartman366] #2231923
01/10/17 10:53 PM
01/10/17 10:53 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
sorry forgot to add the pic
