Re: Fuel cell pics?
[Re: 10sec440]
#223031
02/13/09 02:06 AM
02/13/09 02:06 AM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
I made mine, internal baffles, built in sump, made to fit the space I had... (just welded, the welds looked ugly before being cleaned, sorry! lol)
CrAzYMoPaRGuY
Re: Fuel cell pics?
[Re: 10sec440]
#223035
02/13/09 02:16 AM
02/13/09 02:16 AM
CrAzYMoPaRGuY
Canada
Mine sits on the frame rails with the flanges, I made it so that the sump is below the frame rails. I made the 45 degree edge at the bottom front of the cell for exhaust, the tailpipes wouldn't fit without it.
Are you thinking of an aluminum cell?
CrAzYMoPaRGuY
Re: Fuel cell pics?
[Re: BDS871Cuda]
#223039
02/13/09 09:45 AM
02/13/09 09:45 AM
Posts: 1,890 In the 8's
FY1TA
In the 8's
Just packed in tight and clean . 8 gallon, wish I would of went 16.
Hrrm that would be my car in the pic ???
Re: Fuel cell pics?
[Re: FY1TA]
#223040
02/13/09 10:46 AM
02/13/09 10:46 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Here's a few pics for you. I had a custom alum cell made to fit where my plastic one was. it's about 15 gallons. Old brackets for the plastic 12 gallon cell. I had some brackets welded to the alum cell so I could use the same tabs the straps used. I don't have any good pics from the bottom. It's covered with a belly pan in the car. Here's a completed pic.
Re: Fuel cell pics?
[Re: 70Cuda383]
#223043
02/13/09 11:57 PM
02/13/09 11:57 PM
CrAzYMoPaRGuY
Canada
Top..
you made your own?! hmm...sounds cheaper than buying one for $200!
How thick is that metal? I don't have a tig, or any other set up to weld aluminum, could I make one from mild steel?
I used 12ga aluminum, I still have a large piece...... I don't have an aluminum TIG welder either, I just made all the pieces and went to a buddy of mine who has an aluminum TIG welder.
I didn't do it for cost, I wanted the biggest cell I could fit, and I wanted exact shape, dimensions, baffles etc..
I like Dragula's cell with the built in pump, I assume the pump would be quieter submerged...?
CrAzYMoPaRGuY
Re: Installed Fuel cell pics?
[Re: 10sec440]
#223044
02/14/09 12:01 AM
02/14/09 12:01 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Here's what I did.....
The fuel cell mounting straps,I made from aluminum stock that I bought from Home Depot and bent them myself.The mail order shops wanted $25 for the same thing.Underneath the cell,there is 1" square steel tubing that the straps mount to,and they are the length of the cell.
Re: Fuel cell pics?
[Re: 10sec440]
#223045
02/14/09 12:29 AM
02/14/09 12:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I just used fuel tank straps, they go fore and aft bolted to a cross bar on both ends of the tank. I used what was handy, since I worked in the fuel lab thats what I used...straps both top and bottom sorry no pics EDIT Mine looks very much like Bigcubes
