Installed Fuel cell pics? #223030
02/13/09 02:02 AM
02/13/09 02:02 AM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
Looking for ideas for installation, top and bottom pics if you have them. Thanks.
Re: Fuel cell pics? [Re: 10sec440] #223031
02/13/09 02:06 AM
02/13/09 02:06 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I made mine, internal baffles, built in sump, made to fit the space I had...
(just welded, the welds looked ugly before being cleaned, sorry! lol)
CrAzYMoPaRGuY
Re: Fuel cell pics? [Re: CrAzYMoPaRGuY] #223032
02/13/09 02:07 AM
02/13/09 02:07 AM
Canada
Canada
Top..
CrAzYMoPaRGuY
Re: Fuel cell pics? [Re: CrAzYMoPaRGuY] #223033
02/13/09 02:09 AM
02/13/09 02:09 AM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
Nice job, I edited the topic because I was looking for installation ideas.Thanks for the quick reply!
Re: Fuel cell pics? [Re: CrAzYMoPaRGuY] #223034
02/13/09 02:13 AM
02/13/09 02:13 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Just packed in tight and clean . 8 gallon, wish
I would of went 16.
Snap your neck, mega G-force launch, is all I want!
Re: Fuel cell pics? [Re: 10sec440] #223035
02/13/09 02:16 AM
02/13/09 02:16 AM
Canada
Canada
Mine sits on the frame rails with the flanges, I made it so that the sump is below the frame rails.
I made the 45 degree edge at the bottom front of the cell for exhaust, the tailpipes wouldn't fit without it.
Are you thinking of an aluminum cell?
CrAzYMoPaRGuY
Re: Fuel cell pics? [Re: 10sec440] #223036
02/13/09 02:17 AM
02/13/09 02:17 AM
Canada
Canada
HEY!!!!!!!!!!!
I recognize your car....!!
CrAzYMoPaRGuY
Re: Fuel cell pics? [Re: CrAzYMoPaRGuY] #223037
02/13/09 02:34 AM
02/13/09 02:34 AM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
haha, I recognise that camper...from somewhere!!! Nice install. I had a 5 gal plastic tank and I pulled it out to check on a leak. I figured for what it's worth I would replace it as it's been in the car for 14 years. Now it's getting out of hand, I'm thinking of changing to a 10 gal and re-doing my trunk floor.
Re: Fuel cell pics? [Re: CrAzYMoPaRGuY] #223038
02/13/09 05:07 AM
02/13/09 05:07 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Top..
you made your own?! hmm...sounds cheaper than buying one for $200!
How thick is that metal? I don't have a tig, or any other set up to weld aluminum, could I make one from mild steel?
**Photobucket sucks**
Re: Fuel cell pics? [Re: BDS871Cuda] #223039
02/13/09 09:45 AM
02/13/09 09:45 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
I would of went 16.
Hrrm that would be my car in the pic ???
Re: Fuel cell pics? [Re: FY1TA] #223040
02/13/09 10:46 AM
02/13/09 10:46 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Here's a few pics for you. I had a custom alum cell made to fit where my plastic one was. it's about 15 gallons.
Old brackets for the plastic 12 gallon cell.
I had some brackets welded to the alum cell so I could use the same tabs the straps used.
I don't have any good pics from the bottom. It's covered with a belly pan in the car. Here's a completed pic.
Re: Fuel cell pics? [Re: Bigcube] #223041
02/13/09 01:38 PM
02/13/09 01:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I had to remove the existing plastic fuel cell, and had an aluminum one fabbed to fit the same hole. Before I could have the flanges welded on, it all had to be test fitted to get it right. I had to remove the hold down for the factory jack, as well as the raised section for the gas neck filler tube, then, I determined the leafs were a little too close to leave it square on the bottom, and it had to be sectioned again...Then it was alll fitted up and I redid the entire trunck area.
Re: Fuel cell pics? [Re: Dragula] #223042
02/13/09 11:29 PM
02/13/09 11:29 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Here's what mine looks like.
Re: Fuel cell pics? [Re: 70Cuda383] #223043
02/13/09 11:57 PM
02/13/09 11:57 PM
Canada
Canada
Top..
I used 12ga aluminum, I still have a large piece...... I don't have an aluminum TIG welder either, I just made all the pieces and went to a buddy of mine who has an aluminum TIG welder.
I didn't do it for cost, I wanted the biggest cell I could fit, and I wanted exact shape, dimensions, baffles etc..
I like Dragula's cell with the built in pump, I assume the pump would be quieter submerged...?
CrAzYMoPaRGuY
Re: Installed Fuel cell pics? [Re: 10sec440] #223044
02/14/09 12:01 AM
02/14/09 12:01 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Here's what I did.....
The fuel cell mounting straps,I made from aluminum stock that I bought from Home Depot and bent them myself.The mail order shops wanted $25 for the same thing.Underneath the cell,there is 1" square steel tubing that the straps mount to,and they are the length of the cell.
Nautilus Racing-
Re: Fuel cell pics? [Re: 10sec440] #223045
02/14/09 12:29 AM
02/14/09 12:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I just used fuel tank straps, they go fore and aft
bolted to a cross bar on both ends of the tank. I
used what was handy, since I worked in the fuel lab
thats what I used...straps both top and bottom
sorry no pics
EDIT
Mine looks very much like Bigcubes
Re: Installed Fuel cell pics? [Re: Chris2581] #223046
02/14/09 01:20 AM
02/14/09 01:20 AM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
My old setup was a steel tub like Dragula's last pic and it had a plastic tank in it like Chris2412's and straps I made. The new setup, I bought an RCI 10 gal aluminum tank like Dragula's upper pic and I was going to sink it into the floor the same as in his pic. There are tabs on the side and they have to go to a tube frame. Does there have to be a bottom on it to be legal? (being an aluminum tank)
Re: Installed Fuel cell pics? [Re: 10sec440] #223047
02/14/09 07:24 AM
02/14/09 07:24 AM
NH
torredcuda Offline
torredcuda  Offline
NH
69 Barracuda, stock wheel wells
Re: Installed Fuel cell pics? [Re: torredcuda] #223048
02/14/09 07:25 AM
02/14/09 07:25 AM
NH
torredcuda Offline
torredcuda  Offline
NH
Connected to factory flip gas cap
Re: Installed Fuel cell pics? [Re: 10sec440] #223049
02/14/09 10:55 AM
02/14/09 10:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont have my book in front of me but if I recall
correctly you need a skid plate IF the bottom hangs
EDIT
if the floor has been re worked.... check the book
