Oil pressure Problem Milodon daul line system #2210411
12/09/16 12:12 AM
12/09/16 12:12 AM
Malvern Pa
500ci barracuda Offline OP
Malvern Pa
Riddle me this Bat Man. My oil pressure has been 80 psi cold and 60 psi hot. The car has about 600 miles on it everything is fine excpet the oil psi went to 20 at idle and 40 when you rev thr engine. the only thing I can tell you is the psi never went to 0 psi. Could I have a broken pressure relief spring. I have been using brad penn 10-40 oil. The oil psi stayed at 60 psi through the engine rpm's noe it fluctuates. Mark
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2210417
12/09/16 12:20 AM
12/09/16 12:20 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
First thing I would do is make sure it's tight. Had one back out and pressure dropped about 15 lbs ..
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2210428
12/09/16 12:49 AM
12/09/16 12:49 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Check the filter
....BAD A$$ STREET CAR.....
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2210484
12/09/16 02:39 AM
12/09/16 02:39 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Same answers as above. Check the filter for metal [cut it open ] , while your right there check the pressure relief cap on the oil pump make sure it's tight. I had one back out and lost all oil pressure.
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2210500
12/09/16 03:05 AM
12/09/16 03:05 AM
WI
mopar873 Offline
mopar873  Offline
WI
Same here, I had the cap back out on my '65 Belvedere and my pressure dropped in half. Good luck getting at it in some cars too. I actually took an open end wrench and shaved it down real thin and that did the trick.
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2211077
12/10/16 04:07 AM
12/10/16 04:07 AM
Pound, Va
Chris Vanover Offline
Pound, Va
Mine did the same thing at the beginning of the year and i think it was the #4 cam bearing had came halfway out.
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2211160
12/10/16 12:30 PM
12/10/16 12:30 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine chewed up the pump gears after a broken valve spring. No ther motor damage. Inspection showed the pump spring was broken in 2 pieces as well. I would say there was about a 20-25 psi difference after the repair.
Doug
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2211162
12/10/16 12:40 PM
12/10/16 12:40 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
After you find the problem,I suggest in line screens and NON bypass Moroso oil filters.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2211417
12/10/16 07:53 PM
12/10/16 07:53 PM
Malvern Pa
Malvern Pa
Thanks guys for the info. I will let you know what it is. I am hoping I don't have to take the engine out. Mark
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2211469
12/10/16 08:57 PM
12/10/16 08:57 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
braided supply hoses can be collapsing internally
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2219248
12/22/16 09:35 PM
12/22/16 09:35 PM
Malvern Pa
Malvern Pa
Sofar good news nonthing to worry aboun in the oil. It was clean and real tiny particals in the oil filter. I think they came from the engine breaking in. Also there was on oil on the dip stick. I got punched for that.
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2219278
12/22/16 10:25 PM
12/22/16 10:25 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
If this is a street motor (you stated 600 miles), is there something forcing you to run external oiling? If it's not internal issues causing the fluctuations, I'd pull that off as it's unnecessary overkill x5
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Oil pressure Problem Milodon daul line system [Re: A39Coronet] #2219372
12/23/16 12:36 AM
12/23/16 12:36 AM
Malvern Pa
Malvern Pa
Street and strip. Next year it will be mostly strip NSS. The pump was all new and free as I have to use what is given to me. Plus I had clearance issues inside so I took the easy root. Mark
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2219645
12/23/16 02:56 PM
12/23/16 02:56 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Had it happen before, the relief valve on the oil pump got stuck in the bore.
Joe
Without Data, you’re just another guy with an opinion.
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2219970
12/24/16 01:51 AM
12/24/16 01:51 AM
gregsdart Offline
gregsdart  Offline
It is best to pull the pump and double check everything. You could spin the thing with a priming rod before and after to see any change. The last time I had fluctuation like you describe there was metal in the pump,,,,,,,,,,,jamming the bypass intermittently.
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2225410
01/02/17 10:44 AM
01/02/17 10:44 AM
Malvern Pa
Malvern Pa
I had a chance to go over the oiling system in the car. It had a broken pressure relief spring. I had one and changed it out. I changed the oil 10-30 crossed my fingers and started the car. 63psi cold and 45psi hot. The oil pressure was consistent never moving. Thanks for all the input it helped a lot. I got my ladder bar kit for Christmas it should be going to the fab shop this month and testing at Cecil County this spring. Can't wait
Mark
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2225429
01/02/17 11:31 AM
01/02/17 11:31 AM
Deerfield, Ohio
Deerfield, Ohio
Glad you found it..
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2225514
01/02/17 01:35 PM
01/02/17 01:35 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Glad you found it..
x2 think I'll take a look at mine in the off season, better to be safe than sorry. work
Re: Oil pressure Problem Milodon daul line system [Re: racerx] #2225544
01/02/17 01:58 PM
01/02/17 01:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Glad you found it X3. good-luck testing and have fun.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Oil pressure Problem Milodon daul line system [Re: 500ci barracuda] #2225709
01/02/17 05:22 PM
01/02/17 05:22 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
if you have a weak spring or want to bump up pressure,take off the cap for the spring,and put a 1/4 lock washer in there
