Re: Oil pressure Problem Milodon daul line system
[Re: 500ci barracuda]
#2210484
12/09/16 02:39 AM
12/09/16 02:39 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Same answers as above. Check the filter for metal [cut it open ] , while your right there check the pressure relief cap on the oil pump make sure it's tight. I had one back out and lost all oil pressure.
#2219645
12/23/16 02:56 PM
12/23/16 02:56 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Had it happen before, the relief valve on the oil pump got stuck in the bore.
Joe
Without Data, you’re just another guy with an opinion.
#2219970
12/24/16 01:51 AM
12/24/16 01:51 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
It is best to pull the pump and double check everything. You could spin the thing with a priming rod before and after to see any change. The last time I had fluctuation like you describe there was metal in the pump,,,,,,,,,,,jamming the bypass intermittently.
[Re: racerx]
#2225544
01/02/17 01:58 PM
01/02/17 01:58 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Glad you found it X3. good-luck testing and have fun.
