Re: Biggest Rear Tire Under Stock B Body
[Re: 375inStroke]
#222515
02/13/09 03:06 PM
02/13/09 03:06 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Depends on the body and how low the car is. My 275/60-15 on plain steel 15X7 wheels would rub entering driveways, but on the inside, not the lip. This was on a '69 Coronet with 2" blocks. The wheel lip was about 1/2" above the top of the rim. The leaf strings were weak, so stiffer ones would have helped, I'm sure.
You need to look at back spacing, a tire that size has a ton of room..Coronet & Charger are slightly roomier then Roadrunner & GTX but on my Coronet from the outet wheelwell lip to the inner wheelhouse measures 14.5"....Your running a 10.5" tire.... My buddy is running 305/5015's on 10" wide rallies on his Challenger which has a smaller wheelwell, his car is lowered 3" & the tires never rub... It takes a little effort to get the wheel offset right but you can get allot tire under a B body...
[Re: kzinge1]
#222517
02/13/09 06:40 PM
02/13/09 06:40 PM
340dart4spd
Parts Problem
Parts Problem
I have a '69 Satellite and was wondering what is the biggest tire you guys have put under them? It has a stock width 8 3/4 stock springs and everything. Let me know the Backspacing, rim width, tire size, and if you had to use any spacers. I'm leaning towards a 295/65 on a 15x8 w/ 4.5" BS. I saw this was successfully used under a 69 Charger w/ a 3/16" spacer in the Tech section. Also considering the Hoosier 29x12.5x15 radials and the 28x12x15 M/T Radials. Let me know what you guys have successfully used. Thanks
I had a set of N-50 X 15 ON A 70 CORONET..
