Biggest Rear Tire Under Stock B Body #222510
02/12/09 08:42 PM
02/12/09 08:42 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
I have a '69 Satellite and was wondering what is the biggest tire you guys have put under them?
It has a stock width 8 3/4 stock springs and everything.
Let me know the Backspacing, rim width, tire size, and if you had to use any spacers.
I'm leaning towards a 295/65 on a 15x8 w/ 4.5" BS. I saw this was successfully used under a 69 Charger w/ a 3/16" spacer in the Tech section.
Also considering the Hoosier 29x12.5x15 radials and the 28x12x15 M/T Radials.
Let me know what you guys have successfully used.
Re: Biggest Rear Tire Under Stock B Body [Re: kzinge1] #222511
02/12/09 09:21 PM
02/12/09 09:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
All are workable...Glad your not of the 275/60-15 is as big as it gets mindset...Backspacing gets critical when you start getting into bigger tires & it seems like every car is a little different so what works on some cars may not work on others... The other issue is all the tires you listed are DOT slick type tire & as long as you understand they don't last very long especially if you have a heavy foot & a little horsepower then all is good...BTW my buddy just replaced his Drag T/A's...They had 900 miles on them....
Re: Biggest Rear Tire Under Stock B Body [Re: 1_WILD_RT] #222512
02/13/09 12:21 AM
02/13/09 12:21 AM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
Yeah the 295/65's are the only one's that are drag radials. The other two are the Hoosier radials and the M/T Radials which should last a lot longer. I'll have to pay attention to the BS to get this right, that's why I'm trying to see what other's have done to get a starting point.
Re: Biggest Rear Tire Under Stock B Body [Re: kzinge1] #222513
02/13/09 12:21 AM
02/13/09 12:21 AM
Rochester, NY
superb70 Offline
superb70  Offline
Rochester, NY
295/65R15 M/T Drag radial on a 8.5 rim with 4.5in backspace... Work Great!!
Re: Biggest Rear Tire Under Stock B Body [Re: superb70] #222514
02/13/09 12:23 PM
02/13/09 12:23 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Depends on the body and how low the car is. My 275/60-15 on plain steel 15X7 wheels would rub entering driveways, but on the inside, not the lip. This was on a '69 Coronet with 2" blocks. The wheel lip was about 1/2" above the top of the rim. The leaf strings were weak, so stiffer ones would have helped, I'm sure.
Re: Biggest Rear Tire Under Stock B Body [Re: 375inStroke] #222515
02/13/09 03:06 PM
02/13/09 03:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You need to look at back spacing, a tire that size has a ton of room..Coronet & Charger are slightly roomier then Roadrunner & GTX but on my Coronet from the outet wheelwell lip to the inner wheelhouse measures 14.5"....Your running a 10.5" tire.... My buddy is running 305/5015's on 10" wide rallies on his Challenger which has a smaller wheelwell, his car is lowered 3" & the tires never rub... It takes a little effort to get the wheel offset right but you can get allot tire under a B body...
Re: Biggest Rear Tire Under Stock B Body [Re: kzinge1] #222516
02/13/09 06:35 PM
02/13/09 06:35 PM
moparx Offline
moparx  Offline
i have 29 12.5 hoosiers on 8" ramcharger wheels. the springs are +2"
Re: Biggest Rear Tire Under Stock B Body [Re: kzinge1] #222517
02/13/09 06:40 PM
02/13/09 06:40 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I had a set of N-50 X 15 ON A 70 CORONET..
