Dana 60 trac lok, power lock, eaton posi #2220237
12/24/16 04:04 PM
12/24/16 04:04 PM
Usa
10secchallenger Offline OP
Usa
Ok guys, locking for a carrier for my Dana 60, I was looking at the trac loc, power lock, and also a eaton posi. I'm putting this in a street driven pick up with a fairly stock 440 and will see some strip time.... anyone out there have and experience with these carriers? What good? What sucks.. I only want to do this rear once.
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2220239
12/24/16 04:11 PM
12/24/16 04:11 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the Dana 60 S Trac from Stange in my 68 Charger street strip car, it works GREAT!!!!
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2220245
12/24/16 04:13 PM
12/24/16 04:13 PM
gregsdart Online content
gregsdart  Online Content
Here is an idea if you have a disc type unit already, that is weak.
Not sure which posi name it was, but in a pinch at the track when my Dana posi quit working, I pulled the unit out in the pits and cut the end of a coffee can into a shim to tighten up the discs. It REALY tightened it up, yet was just the right thickness so the case seated properly. No more one wheel wonder burnouts!
Re: Dana 60 trac lok, power lock, eaton posi [Re: gregsdart] #2220249
12/24/16 04:22 PM
12/24/16 04:22 PM
Usa
Usa
Did your case unbolt to access the frictions or was it one piece?
Re: Dana 60 trac lok, power lock, eaton posi [Re: CSK] #2220274
12/24/16 05:04 PM
12/24/16 05:04 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
X2. I bought a strange unit from Cass. So far, so good. He told me its good for 1000hp. I ain't gonna hurt it if that's the case. It handles so nice you would think it was an open diff.
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2220297
12/24/16 05:42 PM
12/24/16 05:42 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We have a Detroit locker. It's been run for a season, we don't notice any clonking on turns and it's supposed to be good for 1000ft/lbs. Though to get someone from Eaton to commit to that was difficult.
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2220315
12/24/16 06:03 PM
12/24/16 06:03 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I have a powerlock in my diesel. It is a rebuilt unit using yukon parts. Way to aggressive in my opinion. It may as well have a spool. It's a dually.
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2220397
12/24/16 08:39 PM
12/24/16 08:39 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Out of those three, the power lock is the way to go.
I have one in my Diplomat that I rebuilt with parts from Dr. Diff and it functions great. Always spins two, might push a little, but doesn't shove me off of corners on icy roads or any thing like that.
Traclocks are junk. I've taken a bunch of covers off of Danas I thought were open diffs to see that they really had a worn out traclock. I wouldn't waste my time with one of em.
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2220440
12/24/16 10:32 PM
12/24/16 10:32 PM
missouri,usa
cryplydog Offline
cryplydog  Offline
missouri,usa
Dana-60 with the powerloc is the only way I would go or if I were going to buy a complete housing and all I think I would try the Strange S-60, they ain't bad on price when you figure the cost of a used one and then rebuilding it.
Re: Dana 60 trac lok, power lock, eaton posi [Re: CSK] #2220446
12/24/16 10:45 PM
12/24/16 10:45 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Ditto.....from Doctor Diff......zero problems....unbolted it from the pallet and slid it in
Mike
Re: Dana 60 trac lok, power lock, eaton posi [Re: SILVER67] #2220452
12/24/16 11:06 PM
12/24/16 11:06 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
power lock is best but trac loc from jy. buy new clutches, if u can add one of the old clutches in and they work pretty good
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2220574
12/25/16 08:27 AM
12/25/16 08:27 AM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
S-Trac for me as well, I really like how it powers through the corners and both wheels spin on the strip, I has Eaton TruTrac's in my 8.75's but had issues with them, don't have those problems now I have the D60 and S-Trac
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2220659
12/25/16 02:34 PM
12/25/16 02:34 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use a Power Lok and it works great.
Nautilus Racing-
Re: Dana 60 trac lok, power lock, eaton posi [Re: Diplomat440] #2220733
12/25/16 04:57 PM
12/25/16 04:57 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I roasted a traclock in one afternoon at the strip with my Polara. The power lock is mega better and best for street use from all the OEM units. I put a spool from Dr. Diff in the Dana I built for the Ramcharger, I would not use a spool on the street.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Dana 60 trac lok, power lock, eaton posi [Re: Polarapete] #2222810
12/29/16 03:10 PM
12/29/16 03:10 PM
Usa
Usa
Thank you for all the replies!!! Good info !!
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2223898
12/31/16 07:26 AM
12/31/16 07:26 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been running a Detroit Locker in my 8-3/4 for about 7 years now with no complaints and it still works great. Ron
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2224374
12/31/16 11:29 PM
12/31/16 11:29 PM
Pasagetdowndena
Cranky Offline
Cranky  Offline
Pasagetdowndena
I'm not a fan of the Crap Loc either.
Re: Dana 60 trac lok, power lock, eaton posi [Re: Cranky] #2224598
01/01/17 11:25 AM
01/01/17 11:25 AM
N.Y.
sixpacksteve Offline
N.Y.
S trac from dr. diff so far so good. if when there's a problem i'll let you know. i only wanted to do this once.
Hell Hath No Fury Like Mine
Re: Dana 60 trac lok, power lock, eaton posi [Re: 10secchallenger] #2224696
01/01/17 01:52 PM
01/01/17 01:52 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I am using a Power Lock, as my car is street/strip and I didn't want to use a spool on the street.
So far it has worked well .
Previously my car had an Olds rear with Ansen spider gear kit to lock it. I never broke it, but I sure hated to push the car by hand! twocents
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Dana 60 trac lok, power lock, eaton posi [Re: Hemi Allstate] #2224817
01/01/17 03:37 PM
01/01/17 03:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Spool.
Doesn't wear out and takes alll the abuse you can throw at it.
Works fine on the street.
'63 Dodge 330
11.19 @ 121 mph
