Re: Dana 60 trac lok, power lock, eaton posi
[Re: 10secchallenger]
#2220239
12/24/16 04:11 PM
12/24/16 04:11 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I have the Dana 60 S Trac from Stange in my 68 Charger street strip car, it works GREAT!!!!
#2220245
12/24/16 04:13 PM
12/24/16 04:13 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Here is an idea if you have a disc type unit already, that is weak. Not sure which posi name it was, but in a pinch at the track when my Dana posi quit working, I pulled the unit out in the pits and cut the end of a coffee can into a shim to tighten up the discs. It REALY tightened it up, yet was just the right thickness so the case seated properly. No more one wheel wonder burnouts!
[Re: CSK]
#2220274
12/24/16 05:04 PM
12/24/16 05:04 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
I have the Dana 60 S Trac from Stange in my 68 Charger street strip car, it works GREAT!!!! X2. I bought a strange unit from Cass. So far, so good. He told me its good for 1000hp. I ain't gonna hurt it if that's the case. It handles so nice you would think it was an open diff.
#2220297
12/24/16 05:42 PM
12/24/16 05:42 PM
Posts: 2,937 A shed in England
Tig
A shed in England
We have a Detroit locker. It's been run for a season, we don't notice any clonking on turns and it's supposed to be good for 1000ft/lbs. Though to get someone from Eaton to commit to that was difficult.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
#2220315
12/24/16 06:03 PM
12/24/16 06:03 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I have a powerlock in my diesel. It is a rebuilt unit using yukon parts. Way to aggressive in my opinion. It may as well have a spool. It's a dually.
[Re: CSK]
#2220446
12/24/16 10:45 PM
12/24/16 10:45 PM
Posts: 784 Liverpool, NY
SILVER67
Liverpool, NY
I have the Dana 60 S Trac from Stange in my 68 Charger street strip car, it works GREAT!!!! Ditto.....from Doctor Diff......zero problems....unbolted it from the pallet and slid it in Mike
#2220659
12/25/16 02:34 PM
12/25/16 02:34 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use a Power Lok and it works great.
[Re: Diplomat440]
#2220733
12/25/16 04:57 PM
12/25/16 04:57 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Out of those three, the power lock is the way to go.
I have one in my Diplomat that I rebuilt with parts from Dr. Diff and it functions great. Always spins two, might push a little, but doesn't shove me off of corners on icy roads or any thing like that.
Traclocks are junk. I've taken a bunch of covers off of Danas I thought were open diffs to see that they really had a worn out traclock. I wouldn't waste my time with one of em. I roasted a traclock in one afternoon at the strip with my Polara. The power lock is mega better and best for street use from all the OEM units. I put a spool from Dr. Diff in the Dana I built for the Ramcharger, I would not use a spool on the street.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Cranky]
#2224598
01/01/17 11:25 AM
01/01/17 11:25 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
S trac from dr. diff so far so good. if when there's a problem i'll let you know. i only wanted to do this once.
Hell Hath No Fury Like Mine
#2224696
01/01/17 01:52 PM
01/01/17 01:52 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I am using a Power Lock, as my car is street/strip and I didn't want to use a spool on the street. So far it has worked well . Previously my car had an Olds rear with Ansen spider gear kit to lock it. I never broke it, but I sure hated to push the car by hand! ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#2224817
01/01/17 03:37 PM
01/01/17 03:37 PM
Posts: 4,704 Wichita
GY3
Wichita
Spool.
Doesn't wear out and takes alll the abuse you can throw at it.
Works fine on the street.
