Page 3 of 3 1 2 3
Re: Strong B-block bottom end for max hp effort [Re: polyspheric] #2223996
12/31/16 01:25 PM
12/31/16 01:25 PM
The Great White North
RAMM Offline
RAMM  Offline
Originally Posted By polyspheric
If the purpose of the girdle is to prevent the pan rail and caps from moving, mild steel of the same thickness is far better than any aluminum.
^^^^^^^^^^^^^^^^This is the way I see it as well. I had a slightly different take on it though and tried to incorporate the best of both aluminum (shock absorbing) and steel for(strength). As many have mentioned a light bob weight and a center counter weighted Bryant or Winberg crank will go a long way. Hardblock it halfway but start with a block that sonics well. I have found that the cylinder strength is a problem and have split cylinders at around the 800 hp range if you get into detonation.
Not sure what cylinder head you are using but valve position sucks so bad in most of the inline valve OEM config'd offerings it wont be all that easy to make 900hp. If you could share the rules it would make helping easier. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224027
12/31/16 02:12 PM
12/31/16 02:12 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I like that set up. What did you do at the rear?
My mods didn't involve a girdle, but used tool steel straps across all 5 main caps. I had seen caps crack apart, and figured the straps would hold it together if they failed. I had to make a reverse lip oil pan at the rear because of the studs/bolts. Held 1100hp (turbo).
I agree with you on cylinder walls. Although mine never cracked, they were a bit barrel shaped(no block filler).
Re: Strong B-block bottom end for max hp effort [Re: AndyF] #2224080
12/31/16 03:17 PM
12/31/16 03:17 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted By AndyF
I made the dry sump pan myself.
Any chance for a production run of those?
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224124
12/31/16 04:58 PM
12/31/16 04:58 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
think ramm and trendz are on to something here,trendz,whats that hole in the rear of block,is that for convertor bolts or cooling
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224129
12/31/16 05:04 PM
12/31/16 05:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The hole is likely just weight, as it surely sacrifices nothing in that area for strength. My "race" blocks, I used to do the same thing as well as grinding off motor mount ears and anything else I could. Can save quite a few pounds but it's a lot of work. I have even seen blocks with that total corner cut off. How many bellhousing bolts do you really need? Where is the trans going? And how many guys have those holes stripped in their trans anyway? They don't do anything. Cut em off
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224140
12/31/16 05:27 PM
12/31/16 05:27 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The hole was for converter bolts, weight was just a side benefit. Because the pan was made with a reverse lip, and was a rear sump, and was very wide, I had no room to get at the converter bolts in the normal sense. Very much an after thought on my part. I didn't realize the issue until it was in the car. Had I realized the issue, I would have built the pan different. Live and learn sawzall
Re: Strong B-block bottom end for max hp effort [Re: TRENDZ] #2224157
12/31/16 05:48 PM
12/31/16 05:48 PM
My thinking on any main support girdle for BB Mopars or other blocks like ours(FE Ford) that doesn't have a press on interference fit girdle onto all of the fasteners, shouldered main studs and shouldered oil pan studs, isn't holding the main caps in place other than front to rear movement. They're not adding strength up in the main webbing where it is needed on the stock RB blocks shruggy
They may look good and make some users fell happy but are they really helping the bottoms of the blocks to become stronger and reduce or stop main webbing cracking and cap walk work shruggy
I do buy and use stronger after market main caps(usually Ductile iron, not steel tsk) and main studs to help prevent main cap breakage for any motor I build that will exceed 600 HP now up
I really wish there was a real fix for the main webbing in the stock blocks, all years of the RB as well as the non cold weather 400 blocks shruggy
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224191
12/31/16 06:35 PM
12/31/16 06:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Admittedly, I have no experience building a motor for a land speed application, but using really light weight internals isn't how I think I'd go about it.
The parts need to be durable enough for an extended period of time under heavy load.
IMO, this is more similar to a marine application than a drag motor.
The acceleration rate is very low, so heavier parts should have almost zero affect on the speed of the vehicle.
I understand the concerns about the mains, but if a rod or wrist pin fails because they arent HD enough, it's all over.
There is going to need to be a balance found between the strength needed for the application vs how light the parts can be.
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224347
12/31/16 10:31 PM
12/31/16 10:31 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Ive been well over a 1000 for a couple years now. Its a 230 block partial fill. steel caps. 3/8" thick girdle, Studs everywhere the girdle. I have also had good results using 3m weatherstrip adhesive on the girdle to block rail. I apply it liberally install the girdle and then bolt it down for a few days to dry before installing the pan. I get zero leaks and no shifting from the girdle. Only sucks at refresh time.. My motor is also boosted so I only spin it to 6800.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224460
01/01/17 01:42 AM
01/01/17 01:42 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
That was always my question on the functionality of girdles. How solid can they be when sandwiched in between gaskets? I always felt that a girdle should be "glued" to the rail, but fastened directly with flush mount tapered locating bolts in an alternate pattern of the pan gasket, so that the girdle isn't dependent on being held in place by a compressible gasket/ hardware.
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224467
01/01/17 01:49 AM
01/01/17 01:49 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my girdle is glued to the rail on one side & only has a gasket on the pan side. the cap studs are doing all the work holding it together, the pan bolts do nothing but hold the pan on
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224512
01/01/17 02:25 AM
01/01/17 02:25 AM
gregsdart Offline
gregsdart  Offline
Look at a KB double bolted block for an idea of what I think would help a stock block live. The double bolt , both top and side, main caps would have to be very large, because the only way to build it would be to build it all below the pan rail. that would create quite a massive add on structure, but if money is not an issue, well, thats' what racers do to win.
The idea is to make the whole deal, main caps and what they are bolted to, so massive that any load put on a single bearing is also transferred to the adjacent two and beyond. That would greatly reduce the stress on the main web area of the cap at the center of the load.
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2224700
01/01/17 01:55 PM
01/01/17 01:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If I used a girdle it would be sealed with anaerobic sealer. For those who don't know its designed the seal two machined halfs. Looks and smells like Locktite. Comes loose very easy when the parts are tapped loose in side shear. Very thin and drys hard between the parts. Drys as soon as there is no air.
Doug
Re: Strong B-block bottom end for max hp effort [Re: TRENDZ] #2225024
01/01/17 07:32 PM
01/01/17 07:32 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
there is no gasket between the girdle and the block on my BCR kit, I used a very light coat of grey silicon between the girdle and pan rail, all the perimeter bolts are studs and the nut's are counter sunk into the girdle, then there is the pan gasket and pan over top of those nut's and that is held in place by another set of nut's on the exsisting pan rail stud's, you can drop the pan and never disturb the girdle, nice well thought out system in my opinion. up
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2225036
01/01/17 07:47 PM
01/01/17 07:47 PM
America
WedgeFED Offline
WedgeFED  Offline
America
Something my Dad created.
Re: Strong B-block bottom end for max hp effort [Re: dartman366] #2225071
01/01/17 09:17 PM
01/01/17 09:17 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Ok. Pretty much what I was thinking on how it should be. Never used one myself.
As for dad's setup there, Pretty dang nice. SKILZ!
Re: Strong B-block bottom end for max hp effort [Re: TRENDZ] #2225088
01/01/17 09:41 PM
01/01/17 09:41 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
he must be a machinist by trade?? look's pretty nice, kind of like the way the small blocks are, cap's are tied together but not to the block/panrail, I used a Hughes on my 408 and they just tie the caps together like that.
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2225244
01/02/17 01:00 AM
01/02/17 01:00 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Since this is a land speed deal and weights probably not a huge issue (maybe a benefit) I'd make a one piece girdle (or bedplate) with the mains intergrated right into them that bolts to the pan rail. Make it maybe 2" above and beyoned the pan rail (probably approximately 4" above the mains)? Cost effective for a normal application? Absolutely not. For a class that requires a stock block but 900+hp to win and you want it to stay together, absolutely. It would also act as a shield as well and keeps parts contained should something fly apart.
Making it from one piece would be best (but $$$), but I guess you could also weld some steel main caps (440source has them) to a thick plate of steel as well and do it that way.
Re: Strong B-block bottom end for max hp effort [Re: WedgeFED] #2226095
01/03/17 01:45 AM
01/03/17 01:45 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
That look interesting. Was this ever run?
1974 Roadrunner
1967 Charger
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2227990
01/05/17 06:37 PM
01/05/17 06:37 PM
America
WedgeFED Offline
WedgeFED  Offline
America
He is a machinist and it is tied to pan rails. He has done a couple of them. This one has not run yet as for he bought a KB block for the Mercedes this go around. He does not like the girdles that tie in with the oil pan bolts so this was his creation. He did not want to cut into the webbing in the block for program caps either.
Page 3 of 3 1 2 3
