Re: 514 on the dyno
[Re: AndyF]
#2222735
12/29/16 01:28 PM
12/29/16 01:28 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Andy, did you back to back c16 vs Q16?
At around that power level I've seen about 35hp myself.
Re: 514 on the dyno
[Re: AndyF]
#2222781
12/29/16 02:35 PM
12/29/16 02:35 PM
fast68plymouth
So. Burlington, Vt.
Is that the Crane cam you had done?
As I recall, that had pretty long duration.
Re: 514 on the dyno
[Re: AndyF]
#2222821
12/29/16 03:27 PM
12/29/16 03:27 PM
Posts: 287 PA
Harry's Taxi 2
PA
Yes, we did back to back X16 to Q16 and picked up almost 30 hp. It takes a little bit of carb work to switch between fuels. BLP set me up with a carb that will switch between 2 circuit for race gas and then 3 circuit for Q16.
I also pulled a little bit of timing out of the motor and that improved things. With less timing the wide bands went leaner and the motor picked up some power. I think I might have had too much timing in it before which might be why the heads got hurt last time.
We're going to try C45 today. The recommendation is more fuel and less timing so I'll follow what VP says and we'll see how it goes.
I also think the cam I have in the engine is too big. We're down a little bit of power from the smaller cam that was in it before. Doesn't really surprise me, at this power level the intake port is probably the choke point and not the valve lift. Valve lift is .890 gross which is probably more than it needs. What ignition timing did you have it at?....and what did you back it down to?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: 514 on the dyno
[Re: fast68plymouth]
#2223049
12/29/16 11:46 PM
12/29/16 11:46 PM
Posts: 31,023 Oregon
AndyF
As I recall, that had pretty long duration. Yep, I have a 282/288 Crane in it now with 481 lobes. The last cam was a Crane 280/286 with 452 lobes. I think the smaller cam made more torque but it is hard to compare. Last time I ran this engine was 3 years ago and the dyno was configured differently. So we could've lost some power from the camshaft, or the dyno cell, or the tuneup. I know I was running more timing and leaner mixture 3 years ago but I also hurt the cylinder head so I might have been on the ragged edge with that old tuneup. Here is a video that shows a couple of pulls on Q16. Correction factor is 98% so we were correcting the power down all day. Engine ran strong all day. Oil filters were very clean so the engine isn't making any trash. The dry sump holds right at 10 inches of vacuum in the pan so not super high vacuum but enough to free up some power and keep the engine dry. https://www.youtube.com/watch?v=2zTAGAy081o&feature=youtu.be
Re: 514 on the dyno
#2223170
12/30/16 03:09 AM
12/30/16 03:09 AM
AndyF
As I recall, that had pretty long duration. I loaded the 514 info into Controlled Induction and it recommends a 271/278 cam with .450 lobes and 109 lobe centers. So I'm about 10 degrees bigger than what Rick Jones thinks I need.
Re: 514 on the dyno
[Re: AndyF]
#2223345
12/30/16 02:04 PM
12/30/16 02:04 PM
fast68plymouth
So. Burlington, Vt.
Any type of build I do along the lines of that motor is going in a bracket car, and pretty much all of my customers want motors that are relatively easy on parts/low-ish maintenance.
So, I end up coming at the cam situation from a different angle for that type of application. The 470 TF testing showed that a faster valve opening rate and more lift do not always bring with them extra power. They pretty much always bring a little(a lot?) of extra wear and tear on the valvetrain.
Instead of looking at how much "more" power can be had from a higher lift, faster rate cam, and/or higher ratio rockers, I often think about how much power will not using something with a fast rate and high lift cost me? And, will the car still run the desired number while using a valvetrain that's easy(er) on parts?
Many times you're messing with 20-30hp(or less) difference between something that will live hundreds of passes with valvetrain parts and spring pressures that are more "middle of the road". On a typical low-9 to low-8 second car, 20-30hp doesn't change the ET very much, but can make a noticeable difference in the maintenance and parts replacement costs and schedule.
Another aspect of running the motor in the car vs the dyno is, sometimes the cam is determined more by what the typical, or necessary rpm requirements are to get the combination to work well, and not solely by what makes the biggest number on the dyno.
Re: 514 on the dyno
[Re: AndyF]
#2223600
12/30/16 08:48 PM
12/30/16 08:48 PM
fast68plymouth
So. Burlington, Vt.
Andy, do you have a good idea about how much power the dry sump is worth, not including the crankcase vacuum(you could get that back with a vacuum pump)?
I guess I wouldn't have thought there would be a 75+hp loss by running a slightly lower CR(13.5-14:1), a more valvetrain friendly cam, 1.7 rockers, wet sump oil system, and a vacuum pump, but I don't remember what you found the dry sump was worth.
Re: 514 on the dyno
[Re: AndyF]
#2223647
12/30/16 10:03 PM
12/30/16 10:03 PM
fast68plymouth
So. Burlington, Vt.
A big box type pan, or a regular car pan for the wet sump test?
Re: 514 on the dyno
[Re: AndyF]
#2251424
02/11/17 02:20 AM
02/11/17 02:20 AM
AndyF
