Monte , al Alguire beadlock question
#2222465
12/28/16 10:22 PM
12/28/16 10:22 PM
Posts: 4,688 On the parachute mount
n20mstr
Al I have seen pics of your Cuda with holeshot wheels. I'm looking to get a 12" beadlock but holeshot only recommends 3 7/8 backspace withnthendouble bead locks. The guy that has been helping me swears I need a 5 or 5.5 backspace. Holeshot says the tire will be very hard to mount on the rim especially a radial. I'm looking to run my 275 radials on a 12" rim. I'm buying rims then narrowing my rear to fit.
Is the beadlock worth it ? And does the backspace matter performance wise ?
....BAD A$$ STREET CAR.....
Re: Monte , al Alguire beadlock question
[Re: Monte_Smith]
#2222483
12/28/16 10:53 PM
12/28/16 10:53 PM
n20mstr
Buy the wheels with the LEAST offset you can get and then make the rear fit. A 12" wheel weighs what it weighs. 2" less axle and tube a side weighs less. That's what I thought , less backspace means a shorter rear and with .250 axle tubes and 40 spline axles I know it's a lot of weight. I can understand why the guy I so adamant that it has to be 5" backspace ? I mean I understand the concept but....?
[Re: n20mstr]
#2222504
12/28/16 11:32 PM
12/28/16 11:32 PM
Posts: 10,038 MN
JERICOGTX
MN
Not sure why Holeshot would say it would be hard to mount the tires? I mounted me me in my living room. Beadlocks make it a breeze.
69 GTX
68 Road Runner
[Re: Monte_Smith]
#2222684
12/29/16 11:36 AM
12/29/16 11:36 AM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I have Weld Magnum 2.0's on my Challenger. They are 15" X 12" with a 5-1/2" back space. Can these be bead locked or no? I have read where some people say certain companies say yes & some say no? Mac fab, Champion, Weld, Hole Shot all do the same processes right? I know the big issue is clearing the brake calipers. With this much back space I should be okay, correct?
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: n20mstr]
#2222702
12/29/16 12:14 PM
12/29/16 12:14 PM
Posts: 10,038 MN
JERICOGTX
MN
MacFab will do wheels up to 5.5" BS. What rear brakes are you using? If Wilwood, you will be OK. I am more then happy with MacFab's work on my wheels. Oh and I have 5.5 BS on my wheels also.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2222719
12/29/16 12:59 PM
12/29/16 12:59 PM
6PKRTSE
Motor City
Okay that's good to hear. Yes, I will be,running Wilwood on the rear to match my fronts.
[Re: SpareParts]
#2222883
12/29/16 05:34 PM
12/29/16 05:34 PM
n20mstr
Tony what is the rear end set up in your car now? What width is it? If you're selling I may be interested in some stuff currently has a 9" with 35 spline strange axles (twisted 1 spline but strange says that's normal?) I have two centers, one alum one with 4.11 and one iron with 3.70. I was going to put a 40 spline MW spool in the alum center...but both centers are for sale ? The rear is 52" stock A body length. THe alum center is the base on that Strange sells, that they say is not strong..
[Re: n20mstr]
#2225739
01/02/17 06:13 PM
01/02/17 06:13 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Another option out there and the lightest one as well would be Neil and Parks. They are used on a lot of Comp Cars out there because they are so light. They are not always the easiest to get ahold of but IMO worth the effort. FWIW more back spacing can make mounting them a bit difficult depending on whos wheels they are. As point out some back section have no teper to them which will make it harder to get the tire on. http://neilparks.com/contact/index.htmhttp://etdragracing.com/race/2015/iii_2-jegspacific/BJ_JustinLamb_AlanEllis-Comp.jpg
