Monte , al Alguire beadlock question #2222465
12/28/16 10:22 PM
12/28/16 10:22 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Al I have seen pics of your Cuda with holeshot wheels. I'm looking to get a 12" beadlock but holeshot only recommends 3 7/8 backspace withnthendouble bead locks. The guy that has been helping me swears I need a 5 or 5.5 backspace. Holeshot says the tire will be very hard to mount on the rim especially a radial. I'm looking to run my 275 radials on a 12" rim. I'm buying rims then narrowing my rear to fit.
Is the beadlock worth it ? And does the backspace matter performance wise ?
....BAD A$$ STREET CAR.....
Re: Monte , al Alguire beadlock question [Re: n20mstr] #2222477
12/28/16 10:38 PM
12/28/16 10:38 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Buy the wheels with the LEAST offset you can get and then make the rear fit. A 12" wheel weighs what it weighs. 2" less axle and tube a side weighs less.
Re: Monte , al Alguire beadlock question [Re: Monte_Smith] #2222483
12/28/16 10:53 PM
12/28/16 10:53 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
That's what I thought , less backspace means a shorter rear and with .250 axle tubes and 40 spline axles I know it's a lot of weight.
I can understand why the guy I so adamant that it has to be 5" backspace ? I mean I understand the concept but....?
Re: Monte , al Alguire beadlock question [Re: n20mstr] #2222504
12/28/16 11:32 PM
12/28/16 11:32 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Not sure why Holeshot would say it would be hard to mount the tires? I mounted me me in my living room. Beadlocks make it a breeze.
69 GTX 68 Road Runner
Re: Monte , al Alguire beadlock question [Re: n20mstr] #2222558
12/29/16 01:09 AM
12/29/16 01:09 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Has to do with the backspace and how the rear halves are made. Some companies, the rear half of wheel is basically straight, no taper, when the wheels have more backspace. Makes the tires hard to get on
Re: Monte , al Alguire beadlock question [Re: Monte_Smith] #2222684
12/29/16 11:36 AM
12/29/16 11:36 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have Weld Magnum 2.0's on my Challenger. They are 15" X 12" with a 5-1/2" back space. Can these be bead locked or no? I have read where some people say certain companies say yes & some say no? Mac fab, Champion, Weld, Hole Shot all do the same processes right? I know the big issue is clearing the brake calipers. With this much back space I should be okay, correct?
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Monte , al Alguire beadlock question [Re: n20mstr] #2222702
12/29/16 12:14 PM
12/29/16 12:14 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
MacFab will do wheels up to 5.5" BS. What rear brakes are you using? If Wilwood, you will be OK. I am more then happy with MacFab's work on my wheels. Oh and I have 5.5 BS on my wheels also.
Re: Monte , al Alguire beadlock question [Re: JERICOGTX] #2222719
12/29/16 12:59 PM
12/29/16 12:59 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Okay that's good to hear. Yes, I will be,running Wilwood on the rear to match my fronts.
Re: Monte , al Alguire beadlock question [Re: n20mstr] #2222845
12/29/16 04:02 PM
12/29/16 04:02 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Tony what is the rear end set up in your car now? What width is it? If you're selling I may be interested in some stuff
Re: Monte , al Alguire beadlock question [Re: SpareParts] #2222883
12/29/16 05:34 PM
12/29/16 05:34 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
currently has a 9" with 35 spline strange axles (twisted 1 spline but strange says that's normal?) I have two centers, one alum one with 4.11 and one iron with 3.70. I was going to put a 40 spline MW spool in the alum center...but both centers are for sale ? The rear is 52" stock A body length. THe alum center is the base on that Strange sells, that they say is not strong..
Re: Monte , al Alguire beadlock question [Re: n20mstr] #2224920
01/01/17 05:20 PM
01/01/17 05:20 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I had a question about beadlocks, do single beadlocks help or is it more for cosmetics? If a person runs beadlocks should you just run double beadlocks? Hope this doesn't hi-jack your thread.
Re: Monte , al Alguire beadlock question [Re: n20mstr] #2225739
01/02/17 06:13 PM
01/02/17 06:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Another option out there and the lightest one as well would be Neil and Parks. They are used on a lot of Comp Cars out there because they are so light. They are not always the easiest to get ahold of but IMO worth the effort.
FWIW more back spacing can make mounting them a bit difficult depending on whos wheels they are. As point out some back section have no teper to them which will make it harder to get the tire on.
http://neilparks.com/contact/index.htm
http://etdragracing.com/race/2015/iii_2-jegspacific/BJ_JustinLamb_AlanEllis-Comp.jpg
