Fender well color #2219727
12/23/16 05:35 PM
12/23/16 05:35 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Were the fender wells painted body color or painted black? I am working on a 70 Cuda. TIA
Re: Fender well color [Re: gregok] #2219750
12/23/16 06:31 PM
12/23/16 06:31 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
The fender wells were coated in undercoating which was black.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Fender well color [Re: MOPARMIKE69] #2219845
12/23/16 09:30 PM
12/23/16 09:30 PM
Washington/Las Vegas
1971 Gran Coupe Offline
Correct, undercoating (black) went on after the body was painted and the fender wells were painted the same color.
Re: Fender well color [Re: gregok] #2219918
12/23/16 11:49 PM
12/23/16 11:49 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The whole car is painted body color. The wheel houses are undercoated after painting. You should look for some examples to see where the typical limits of the undercoating was applied.
Re: Fender well color [Re: RoadRunnerJD] #2219965
12/24/16 01:27 AM
12/24/16 01:27 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Okay, thanks guys.
Re: Fender well color [Re: RoadRunnerJD] #2219997
12/24/16 03:20 AM
12/24/16 03:20 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed...
Re: Fender well color [Re: DAYCLONA] #2219998
12/24/16 03:26 AM
12/24/16 03:26 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Fender well color [Re: gregok] #2220035
12/24/16 10:37 AM
12/24/16 10:37 AM
MA
steve70 Offline
steve70  Offline
MA
But what about LA built cars? My understanding is the LA built cars didn't get undercoating in the front wheel wells but got a black out treatment like the radiator support so you didn't see body color.
1970 Challenger T/A 4 speed
Re: Fender well color [Re: steve70] #2220056
12/24/16 11:43 AM
12/24/16 11:43 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
agreed, the LA build variations are often overlooked vs Hamtramck built cars
Re: Fender well color [Re: steve70] #2220319
12/24/16 06:08 PM
12/24/16 06:08 PM
Had not heard this one, so I just went out and looked at my LA Dealer Promo car survivor. It has undercoating on both front wheel wells, but now get this, never noticed, NO PAINT. You can see the metal and the dip effects. I will try and get some pictures when I get some more time. Like the old saying, when it comes to Mopar, never say never.
Re: Fender well color [Re: gregok] #2220356
12/24/16 07:18 PM
12/24/16 07:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm sure there were occasional variations depending on human factors, but basically, the cars were primered, then painted, then undercoated. Primer under most everything, paint color oversprayed into wheel wells and outer areas of floor, undercoating hosed into wheelwells after some masking of attachment points & access covers.
Paint overspray is usually pretty light in areas where part of the car was in the way of the spray pattern. My '68 - '69 non-L.A. cars had a medium-grey primer, like the green Cuda above, but not as light as the purple Cuda appears to be.
Re: Fender well color [Re: 1971 Gran Coupe] #2220358
12/24/16 07:24 PM
12/24/16 07:24 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
And is that dip a dark color?
Does the car have undercoating all under it? Is it a A/C car?
Re: Fender well color [Re: autoxcuda] #2220364
12/24/16 07:40 PM
12/24/16 07:40 PM
I will say the dip color is dark, when compared to my 71 GranCoupe, which is a Hamtramck production. The car has full undercoat and yes, it is an AC car.
Re: Fender well color [Re: gregok] #2220369
12/24/16 07:42 PM
12/24/16 07:42 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Past discussion on LA built cars with their different dip colors:
https://board.moparts.org/ubbthreads/ubbt...-questions.html
Re: Fender well color [Re: 1971 Gran Coupe] #2220377
12/24/16 07:48 PM
12/24/16 07:48 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's a 68 LA built Dart A-body that did not come with factory undercoat.
Before media blasting
After media blasting
5995534-Troy5_14_10DartSm07.JPG5997867-Troy5_14_10DartSm17.JPG5997906-Troy3_19_10DartSm4.JPG
Re: Fender well color [Re: steve70] #2220628
12/25/16 01:27 PM
12/25/16 01:27 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
I looked at some pics of my 10/69 SPD LA built cuda before disassembly and the front fender wells did not have factory undercoating. Also original paint coverage was not great in the fender wells. Mostly primer and b7 overspray.
Super Commando
