Page 2 of 3 1 2 3
Re: My New Best - Brazil [Re: 360tripleblack77] #2217541
12/20/16 03:50 AM
12/20/16 03:50 AM
Cab_Burge Online work
Cab_Burge  Online Work
Take a hard look at the shock lengths, your shackles may need a little more back angle but look at the shock length first and correct that If needed and then run the car again before doing anything else twocents
You might want to look at the Rancho brand ten way adjustable rear drag shocks also scope
Re: My New Best - Brazil [Re: Monte_Smith] #2217580
12/20/16 08:17 AM
12/20/16 08:17 AM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Thank you Monte!
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: My New Best - Brazil [Re: Thumperdart] #2217583
12/20/16 08:28 AM
12/20/16 08:28 AM
Originally Posted By Thumperdart
Originally Posted By 360tripleblack77
Originally Posted By Cab_Burge
Any idea what the humidity and barometric pressures where on that day? Looking at the color of the grass I would bet money it is very humid their work Which means a lot of humidity means thin air shruggy
I would focus on getting rid of the bouncing when leaving the starting line, look at the rear leaf spring angle first at rest and then jack the car up so the rear tires are off the ground and the suspension is not loaded, don't jack it up by the rear end housing and leave it on the jack in other words tsk
If the rear spring shackles are pointed straight down or pointed slightly forward from the upper eye then see about relocating the eye forward one or two inches in it or making the upper bracket longer with the bolt holes further forward so the shackles will be pointed back toward the leaf spring eye at rest and not pointed straight down or forward under acceleration scope
Fixing the shackle angle will make your sixty foot times better, that should eliminate the bouncing also, if that is what is causing it shruggy
Please let us know what you find out and what you decide to do thumbsBTW, what body style,A,B or? is your car confused It looks like a 1970 Plymouth B body from the passenger side and looks some what like a 1967 to 1976 Dart A body from the drivers side confused
Nice car up bow
f you bet your money at humidity you will don't loss them! lol Humidity was 63% and barometric pressure was 27.76in.
About the shackles, I think that you found my problem. I was back to garage with two pictures as you suggested and look at this:
Car on the jack, suspension no loaded
Car on the ground
I'm looking to make my own Sliders to change shackles. I believe that sliders will fix this problem. What do you think?
About the car, is an A-Body same body of 67-69 Dart. In Brazil when Charger was annouced they was a more powerfull version of Dart with some stetics and engine changes. In Brazil all Mopars was equipped with 318 but Dart had 198HP and Charger 215HP.
I know this is very weird for you. Charger A Body? Yes, in Brazil this was possible. laugh
Been down that road and yes, sliders will fix that as long as you set em up correctly. I installed mine a few years ago and love em even on the street...........
Thanks Dominic! This was a doubts that I had about sliders. Will works good at the Street also? Thanks for share this information.
BTW Could you tell me what's your reccomendation to install sliders on my car?
Best 1/8 mile ET
Re: My New Best - Brazil [Re: Cab_Burge] #2217587
12/20/16 09:04 AM
12/20/16 09:04 AM
Thanks Man! For sure, tonight I will check shocks lenght. Some recomendation how can I measure this correctly?
Best 1/8 mile ET
Re: My New Best - Brazil [Re: 360tripleblack77] #2217645
12/20/16 11:47 AM
12/20/16 11:47 AM
an8sec70cuda Offline
Am I the only one seeing what looks like a pretty heavy/stiff leaf spring on this car? You should be considering some monoleaf springs along w/ good shocks.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: My New Best - Brazil [Re: 360tripleblack77] #2217930
12/20/16 07:01 PM
12/20/16 07:01 PM
Thanks Man! For sure, tonight I will check shocks lenght. Some recomendation how can I measure this correctly? [/quote]
Jack it up again like in your pictures and remove the lower shock retaining nut and washer and slide the shock off the stud and see if it will extend downward another 1/2 inch or more scope If it does your good thumbs which I suspect it won't be good scope If the rear end goes downwards a little bit when the shock is slid off the stud you need longer shocks thumbs
Your rear shackle angle at rest looks good now, I will bet money that the shocks are to short twocents
Re: My New Best - Brazil [Re: Cab_Burge] #2217962
12/20/16 08:13 PM
12/20/16 08:13 PM
Your rear shackle angle at rest looks good now, I will bet money that the shocks are to short twocents [/quote]
Mr Cab, I think that you lose your money at this time. Lol... I did check right now and looks good extension.
Shocks has 21.5" full extend.
Best 1/8 mile ET
Re: My New Best - Brazil [Re: 360tripleblack77] #2217972
12/20/16 08:37 PM
12/20/16 08:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Shock length looks fine.. but you have
a big stack of leafs in there.. what
springs are on there.. also you need to
look at the front of the car.. measure the
fender with the weight and driver in the
seat.. then jack up the body to JUST lift
the tire and re-measure.. that change in
travel SHOULD be like 5".. also good rear
adjustable shocks.. as said the Rancho 9 ways
are a fair shock since your not a all out race
car
wave
Re: My New Best - Brazil [Re: 360tripleblack77] #2218139
12/21/16 12:56 AM
12/21/16 12:56 AM
K
KOS Offline
KOS  Offline
K
super cool ride never seen one before....kinda similiar to the aussie stuff but even better smile
Re: My New Best - Brazil [Re: 360tripleblack77] #2218219
12/21/16 04:35 AM
12/21/16 04:35 AM
I'm baffle now on what exactly is causing your bouncing off the starting line, but keeping in mind some of the laws of physics that like for every action there is a opposite and equal reaction work
With that in mind I would now do like Mike(MrPbody)suggest to find out what is causing the rear of the car to porpoise and unload the rear suspion thumbs scope
The key to good sixty foot times is keeping the car glue to the track during the entire run, not just the last part shruggy
Good luck, let us know what you do and the effects on your car thumbs
Re: My New Best - Brazil [Re: MR_P_BODY] #2218237
12/21/16 08:24 AM
12/21/16 08:24 AM
car
wave
Mike, I'm using OEM leaf springs (this junk is heavy) but in the future I would like to buy Calvert mono leaf.
Last Night I did measure front end travel as you asked lifting the car by K-Member, That's right? If yes, front end travel is 4"
So, about the Shocks, my concern is also about durability. I was looking for Vikings but as you know I live in Brazil and buy parts in US is very expensive for me. I can't buy Shocks every year. So if Rancho 9 ways will works for my application will be perfect because is not so expensive than Vikings or QA1.
Thanks for your advices Mike!
Best 1/8 mile ET
Re: My New Best - Brazil [Re: 360tripleblack77] #2218254
12/21/16 10:54 AM
12/21/16 10:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Between the Vikings and the Rancho 9 ways.. I
would buy the Viking adjustables
wave
Re: My New Best - Brazil [Re: MR_P_BODY] #2218429
12/21/16 03:54 PM
12/21/16 03:54 PM
wave
Mike, Who sells Vikings Shocks? I can't find any seller to buy by internet
Best 1/8 mile ET
Re: My New Best - Brazil [Re: KOS] #2218430
12/21/16 03:57 PM
12/21/16 03:57 PM
Thanks Man! Was a very cool ride!
Best 1/8 mile ET
Re: My New Best - Brazil [Re: 360tripleblack77] #2218449
12/21/16 04:40 PM
12/21/16 04:40 PM
Best 1/8 mile ET
Re: My New Best - Brazil [Re: 360tripleblack77] #2218456
12/21/16 05:03 PM
12/21/16 05:03 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
In my opinion, it's EASY to see why it bounces. It's got a fairly stiff segment(by the way you need more clamps on front) not huge power and basically ZERO housing control because of the shocks. So it's got enough uummph to flex the spring, but it can't hold it and the shocks are doing nothing. That's just my thoughts though
Re: My New Best - Brazil [Re: 360tripleblack77] #2218527
12/21/16 07:12 PM
12/21/16 07:12 PM
K
KOS Offline
KOS  Offline
K
looks like one of the quickest cars there!!!!nice makes us mopar guys proud.
i would do both shocks and sliders asap.have you ever run it without the bars?my 68charger runs about the same with low 1.5s 60ft with just leafs similiar to yours rancho 9ways set 5-7clicks full stiff no bars.my 70 dart ran mid 1.3s with just Super Stocks and CE 3ways.i went to full calvert setup and gained nothing.just some food for thought.......
Re: My New Best - Brazil [Re: 360tripleblack77] #2219362
12/23/16 12:28 AM
12/23/16 12:28 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Curious where the track is. I know its not close to you, but I believe there is a track in Curitiba. I go to that area several times a year and always wanted to go to an event but has not yet worked out.
Re: My New Best - Brazil [Re: Monte_Smith] #2219461
12/23/16 08:28 AM
12/23/16 08:28 AM
Thank you Monte! I really appreciate your advices. Your suggestion is add more clamps in the front spring segment + good shocks also?
Best 1/8 mile ET
Re: My New Best - Brazil [Re: KOS] #2219470
12/23/16 09:30 AM
12/23/16 09:30 AM
Thanks Man! Car ran very good for me because my old best time was 7.35@98.20
In the past, I ran without bars and was terrible I had Wheel Hop. About the shocks and sliders, this is the plan plus mono leaf springs...
Best 1/8 mile ET
Page 2 of 3 1 2 3
