motor plates? How to locate them? #221559
02/11/09 08:33 PM
02/11/09 08:33 PM
west palm beach, florida
modelmakerinc Offline OP
If you are planning on using a motorplate to mount the engine How do you determine the height the engine should be placed.
for example I have a slant six k-frame, I want to install a 440, Where does one measure to get the correct placement. Thanks
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: motor plates? How to locate them? [Re: modelmakerinc] #221560
02/11/09 08:54 PM
02/11/09 08:54 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I made a template from the frame rails to my original crankshaft bolt (center) and used that. But I think the measurements are on Shumockers Conversion Motor mounts web site and there may be some measurments/drawings in the Mopar Chassis manual.
SRT DEMON ONE SEAT
Re: motor plates? How to locate them? [Re: modelmakerinc] #221561
02/11/09 09:08 PM
02/11/09 09:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depends what you are doing with the car, drag car
and you might want more weight transfer... raise it
up some.... you measure from the centerline of the crank
Re: motor plates? How to locate them? [Re: MR_P_BODY] #221562
02/11/09 11:12 PM
02/11/09 11:12 PM
Newark, OH
springers340dart Offline
Newark, OH
if ya need a big block motor plate and or mid plate i got one i'll sell, don't need it anymore since i'm running small block, mid plate hasn't been used yet but motor plate for last 3 months of season, solid motor plate.
Re: motor plates? How to locate them? [Re: springers340dart] #221563
02/11/09 11:33 PM
02/11/09 11:33 PM
Thanks I am not at that point yet.
I am looking to find a dimension of where a 440 goes in relationship to the car.
If my coronet had a bigblock mounted on the factory motor mounts it would be easy to take measurements, however the car has a slant 6 k-frame.
a left to right dimension would also be helpful.
Re: motor plates? How to locate them? [Re: modelmakerinc] #221564
02/11/09 11:40 PM
02/11/09 11:40 PM
AndyF Online content
AndyF  Online Content
Buy the CNC machined motor plate from Mancini Racing. They are designed to locate the engine in the correct location.
Re: motor plates? How to locate them? [Re: AndyF] #221565
02/11/09 11:45 PM
02/11/09 11:45 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
No cutting? So the A-body one drops right onto the frame rails? Is there a crank pulley spacer available?
Sorry to hijack.
I'm Gumby dammit!
Re: motor plates? How to locate them? [Re: Gumbydammit] #221566
02/11/09 11:58 PM
02/11/09 11:58 PM
thanks Andy. But not to be ungrateful But I am looking for the dimensions. If I were to buy the motor plate from Mancini, I would still feel more comfortable measuring it to double check that i placed it correctly
Re: motor plates? How to locate them? [Re: Gumbydammit] #221567
02/12/09 01:02 AM
02/12/09 01:02 AM
Sorry to hijack.
No cutting, mounts on the frame rails and puts the motor in the correct location (probably doesn't work with the early A body cars though). There is a 3/8 crank spacer available from Mancini also.
Re: motor plates? How to locate them? [Re: AndyF] #221568
02/12/09 01:57 AM
02/12/09 01:57 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i did mine with the eyeometer. no measuring required. just bolted in an empty tranny case to the cross member, attached the csr shield, bolted up an empty block & jacked it up til the csr touched the tunnel, attached the motor plate to the block & welded in the mounting tags. i used comp eng motor plates & they slipped nicely between the rails. stock oil pan could still be fitted whilst the block was in place. tooo easy.
Re: motor plates? How to locate them? [Re: MR_P_BODY] #221569
02/12/09 02:02 AM
02/12/09 02:02 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
MR P BODY - Iam going to do the same. But how much is enough to raise the motor from stock location? Iam talkeing about my `74 Charger ?
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: motor plates? How to locate them? [Re: AndyF] #221570
02/12/09 02:27 AM
02/12/09 02:27 AM
Utah
topbrent Offline
topbrent  Offline
Utah
What about locating the fore-aft position of the motor?
Re: motor plates? How to locate them? [Re: modelmakerinc] #221571
02/12/09 05:21 AM
02/12/09 05:21 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
TTI has the dimesions on their website.
Center of the crankshaft to top of K-frame - 5.25"
Measure from the center of the crankshaft to each framerail. Difference between the two measurements should be 2.5". Engine is offset to passenger side.
Re: motor plates? How to locate them? [Re: topbrent] #221572
02/12/09 05:23 AM
02/12/09 05:23 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Mock it up with the trans bolted on using the stock trans mount. That will position it correctly fore/aft.
Re: motor plates? How to locate them? [Re: rebel] #221573
02/12/09 10:15 AM
02/12/09 10:15 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thats the way i do it,if you have the tranny bolted to the crossmember its got to be right on,then if you want it a little further back you can take your measurement from there.but remember your tranny sheild you have to allow for that.
Re: motor plates? How to locate them? [Re: Georg] #221574
02/12/09 10:22 AM
02/12/09 10:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That would depend on what you use for a hood, if you
could raise it up 4" it would help alot(trying to
get the engine closer to the CG of the car) but it
also depends on the HP level you will make, the higher
the HP the lower it needs to be
Re: motor plates? How to locate them? [Re: bonefish] #221575
02/12/09 10:35 AM
02/12/09 10:35 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
That was my concern. Should it be lower to more easily fit a carb fiber tranny shield. I had not thought about how this would affect weight transfer as per Pbodies suggestion
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: motor plates? How to locate them? [Re: Kam*Kuda] #221576
02/12/09 11:51 AM
02/12/09 11:51 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
no matter what you do if your going to run a tranny sheild you will have to hammer flat the pinch weld between the tunnel and fire wall,then you can put the engine in the stock location or lower it 1/4 in. but if you you lower it make shure your drag link isnt to hi and rubs where it goes thru the pan.
Re: motor plates? How to locate them? [Re: MR_P_BODY] #221577
02/13/09 09:28 AM
02/13/09 09:28 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Motor is coming XR-2 / P7 combo so at least 750hp.
Hood is no proble because it`s allready have scoop and that`s easiest part to make new higher scoop if needed. So 3-4" lift should be ok? So I need to raise tranny mount also same level, right?
Re: motor plates? How to locate them? [Re: Georg] #221578
02/14/09 07:30 AM
02/14/09 07:30 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Not to sound like a dumb#$#,,,but
What is the advantage of running a motor plate ?
Is it the ease of getting the motor in and out ?
Is it more sturdy than solid mounts ?
Anyone with a pic or info on the Mancini motor plate ?
What do you have to do to the frame rails in the engine bay
