Re: motor plates? How to locate them?
[Re: modelmakerinc]
#221560
02/11/09 08:54 PM
02/11/09 08:54 PM
Posts: 1,880 USA
Ron Silva
USA
I made a template from the frame rails to my original crankshaft bolt (center) and used that. But I think the measurements are on Shumockers Conversion Motor mounts web site and there may be some measurments/drawings in the Mopar Chassis manual.
SRT DEMON ONE SEAT
[Re: modelmakerinc]
#221561
02/11/09 09:08 PM
02/11/09 09:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Depends what you are doing with the car, drag car and you might want more weight transfer... raise it up some.... you measure from the centerline of the crank
[Re: Gumbydammit]
#221567
02/12/09 01:02 AM
02/12/09 01:02 AM
Posts: 30,995 Oregon
AndyF
Buy the CNC machined motor plate from Mancini Racing. They are designed to locate the engine in the correct location.
No cutting? So the A-body one drops right onto the frame rails? Is there a crank pulley spacer available?
Sorry to hijack.
No cutting, mounts on the frame rails and puts the motor in the correct location (probably doesn't work with the early A body cars though). There is a 3/8 crank spacer available from Mancini also.
[Re: AndyF]
#221570
02/12/09 02:27 AM
02/12/09 02:27 AM
Posts: 793 Utah
topbrent
Utah
What about locating the fore-aft position of the motor?
[Re: modelmakerinc]
#221571
02/12/09 05:21 AM
02/12/09 05:21 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
thanks Andy. But not to be ungrateful But I am looking for the dimensions. If I were to buy the motor plate from Mancini, I would still feel more comfortable measuring it to double check that i placed it correctly
TTI has the dimesions on their website.
Center of the crankshaft to top of K-frame - 5.25" Measure from the center of the crankshaft to each framerail. Difference between the two measurements should be 2.5". Engine is offset to passenger side.
[Re: topbrent]
#221572
02/12/09 05:23 AM
02/12/09 05:23 AM
G_bob
Riverside, Ca
Mock it up with the trans bolted on using the stock trans mount. That will position it correctly fore/aft.
[Re: rebel]
#221573
02/12/09 10:15 AM
02/12/09 10:15 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i did mine with the eyeometer. no measuring required. just bolted in an empty tranny case to the cross member, attached the csr shield, bolted up an empty block & jacked it up til the csr touched the tunnel, attached the motor plate to the block & welded in the mounting tags. i used comp eng motor plates & they slipped nicely between the rails. stock oil pan could still be fitted whilst the block was in place. tooo easy.
thats the way i do it,if you have the tranny bolted to the crossmember its got to be right on,then if you want it a little further back you can take your measurement from there.but remember your tranny sheild you have to allow for that.
[Re: Georg]
#221574
02/12/09 10:22 AM
02/12/09 10:22 AM
MR_P_BODY
MR P BODY - Iam going to do the same. But how much is enough to raise the motor from stock location? Iam talkeing about my `74 Charger ?
That would depend on what you use for a hood, if you could raise it up 4" it would help alot(trying to get the engine closer to the CG of the car) but it also depends on the HP level you will make, the higher the HP the lower it needs to be
