Hemi Turbo Question
#2214440
12/15/16 02:31 PM
12/15/16 02:31 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I have a 582" Hemi with Indy 426-1RA heads that have been ported to the max. The intake runner have epoxy due to going through to the water jacket. Are the runner to thin to put under boost and have you ever run a boosted runner with epoxy?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Hemi Turbo Question
[Re: 65 Hemi]
#2214444
12/15/16 02:43 PM
12/15/16 02:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I had a intake runner with epoxy without any added pressure.. just the thermo expansion and cooling the epoxy came loose.. this was with about 400 miles on it.. I wouldnt want epoxy in a pressurized set up.. JMO
[Re: 65 Hemi]
#2214504
12/15/16 04:03 PM
12/15/16 04:03 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Depends how much boost you are talking. 7 psi I wouldn't care, 21 psi would be a different story.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 65 Hemi]
#2214610
12/15/16 07:46 PM
12/15/16 07:46 PM
65 Hemi
San Diego CA
I'm thinking 25-30 lbs of boost...
Doug
[Re: 65 Hemi]
#2214680
12/15/16 09:18 PM
12/15/16 09:18 PM
Posts: 17 Dover,, Pa
hemiaddict
Dover,, Pa
They are aluminum, Take the epoxy out, weld them up, smack it with all the boost you want. Jr
Jr Baum SS/AH 1979
[Re: hemiaddict]
#2214822
12/16/16 12:20 AM
12/16/16 12:20 AM
65 Hemi
San Diego CA
Doug
[Re: 65 Hemi]
#2214942
12/16/16 04:25 AM
12/16/16 04:25 AM
MR_P_BODY
I assume the hole is in the bottom epoxy area in that pic.. looks like a easy area to weld up... might cost you a few bucks but it would be well worth the cost... he could weld that up through the valve opening with the valve out
