Hemi Turbo Question #2214440
12/15/16 02:31 PM
12/15/16 02:31 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I have a 582" Hemi with Indy 426-1RA heads that have been ported to the max. The intake runner have epoxy due to going through to the water jacket. Are the runner to thin to put under boost and have you ever run a boosted runner with epoxy?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Hemi Turbo Question [Re: 65 Hemi] #2214444
12/15/16 02:43 PM
12/15/16 02:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a intake runner with epoxy without any added
pressure.. just the thermo expansion and cooling the
epoxy came loose.. this was with about 400 miles on
it.. I wouldnt want epoxy in a pressurized set up.. JMO
wave
Re: Hemi Turbo Question [Re: 65 Hemi] #2214504
12/15/16 04:03 PM
12/15/16 04:03 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Depends how much boost you are talking. 7 psi I wouldn't care, 21 psi would be a different story.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Hemi Turbo Question [Re: 65 Hemi] #2214610
12/15/16 07:46 PM
12/15/16 07:46 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I'm thinking 25-30 lbs of boost...
Doug
MOPAR or NO CAR!!!
Re: Hemi Turbo Question [Re: 65 Hemi] #2214615
12/15/16 07:56 PM
12/15/16 07:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd be scared to blow the port out then suck oil in.
But if it holds you will make 2000HP
Re: Hemi Turbo Question [Re: 65 Hemi] #2214645
12/15/16 08:35 PM
12/15/16 08:35 PM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
I like the way you think!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi Turbo Question [Re: 65 Hemi] #2214647
12/15/16 08:36 PM
12/15/16 08:36 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
No way. Indy heads crack at the best of times
Re: Hemi Turbo Question [Re: 65 Hemi] #2214680
12/15/16 09:18 PM
12/15/16 09:18 PM
Dover,, Pa
hemiaddict Offline
hemiaddict  Offline
Dover,, Pa
They are aluminum, Take the epoxy out, weld them up, smack it with all the boost you want. Jr
Jr Baum
SS/AH 1979
Re: Hemi Turbo Question [Re: hemiaddict] #2214822
12/16/16 12:20 AM
12/16/16 12:20 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Doug
MOPAR or NO CAR!!!
Re: Hemi Turbo Question [Re: 65 Hemi] #2214942
12/16/16 04:25 AM
12/16/16 04:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume the hole is in the bottom epoxy area in that
pic.. looks like a easy area to weld up... might cost
you a few bucks but it would be well worth the cost...
he could weld that up through the valve opening with the
valve out
wave
