70 Charger firewall plug? #2208474
12/06/16 12:36 AM
12/06/16 12:36 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
There are rubber plugs that are used to fill the firewall insulation push pin holes not being used on Chargers (all 66-70 B bodies?) with AC.
Are these available new anywhere?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 70 Charger firewall plug? [Re: 71TA] #2208479
12/06/16 12:43 AM
12/06/16 12:43 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
These Cheby firewall plugs look close.
Re: 70 Charger firewall plug? [Re: 71TA] #2208522
12/06/16 01:58 AM
12/06/16 01:58 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Same on other b-bodies with A/C. Never looked for them so unsure of availability.
Re: 70 Charger firewall plug? [Re: 71TA] #2208719
12/06/16 02:24 PM
12/06/16 02:24 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I don't think these plugs or the grommet with 3 holes that vacuum hoses go thru are being reproduced. Something I guess I'm obligated to make since we do all the heater box and firewall related stuff.
Re: 70 Charger firewall plug? [Re: 71TA] #2208784
12/06/16 04:14 PM
12/06/16 04:14 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Good idea up
Re: 70 Charger firewall plug? [Re: 71TA] #2209104
12/07/16 01:02 AM
12/07/16 01:02 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Only 2 holes / lines through that grommet. Will double check the number.
Re: 70 Charger firewall plug? [Re: NANKET] #2210170
12/08/16 05:55 PM
12/08/16 05:55 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Are there 2 different ones? I know the ones I saw looked like a recessed floor plug but with 3 holes for the hidden headlight hoses. I see thse at the shows and online for like $100 with the hoses.
Re: 70 Charger firewall plug? [Re: 71TA] #2210201
12/08/16 06:48 PM
12/08/16 06:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 Coronet with AC - 2 hoses.
I am deleting the AC on this car, so if you need the two plugs for patterns, just holler.
Re: 70 Charger firewall plug? [Re: Alaskan_TA] #2212082
12/11/16 09:16 PM
12/11/16 09:16 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Hollering smile
Tried PM but says you aren't accepting. I am so shoot me a message.
PS What are the hoses to going thru that 2 hole grommet. I know the 3 hole grommet is for the hidden headlights on a Charger.
Re: 70 Charger firewall plug? [Re: 71TA] #2212136
12/11/16 10:00 PM
12/11/16 10:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They were cut when I bought the car, but I can look into it.
PMs do not work for me, so drop me a line at sixpak340(insert at symbol here)att.net
Re: 70 Charger firewall plug? [Re: 71TA] #2212309
12/12/16 02:02 AM
12/12/16 02:02 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
One hose goes to the vacuum storage can under the battery tray. The other goes to the vacuum diaphragm on the heater control valve.
Re: 70 Charger firewall plug? [Re: NANKET] #2212372
12/12/16 10:02 AM
12/12/16 10:02 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Well, this is a timely subject for me. I'm just finishing up a 70 Charger with A/C and I forget about that vacuum can. Does the hose that goes to the can have a splice in it right at the firewall or does it go all the way from the can through the grommet to the inside?
Re: 70 Charger firewall plug? [Re: Alaskan_TA] #2216015
12/18/16 02:06 AM
12/18/16 02:06 AM
IL.
U
Upholstery guy Offline
U
IL.
If 71TA doesn't need the plugs for a pattern let me know I can use them on my 70 Charger restoration.
Re: 70 Charger firewall plug? [Re: 71TA] #2216104
12/18/16 11:04 AM
12/18/16 11:04 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
He wants them, but after that they will be reproduced & available for anyone that needs them.
Re: 70 Charger firewall plug? [Re: 71TA] #2217478
12/20/16 02:18 AM
12/20/16 02:18 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
That hose has a splice in it about 6" from the firewall, looked at 2 1970 cars that are pretty original.
Re: 70 Charger firewall plug? [Re: NANKET] #2217597
12/20/16 10:04 AM
12/20/16 10:04 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
