70 Charger firewall plug?
#2208474
12/06/16 12:36 AM
12/06/16 12:36 AM
Posts: 12,425 Warren, MI
71TA
Warren, MI
There are rubber plugs that are used to fill the firewall insulation push pin holes not being used on Chargers (all 66-70 B bodies?) with AC.
Are these available new anywhere?
Re: 70 Charger firewall plug?
[Re: NANKET]
#2210170
12/08/16 05:55 PM
12/08/16 05:55 PM
71TA
Warren, MI
Only 2 holes / lines through that grommet. Will double check the number. Are there 2 different ones? I know the ones I saw looked like a recessed floor plug but with 3 holes for the hidden headlight hoses. I see thse at the shows and online for like $100 with the hoses.
[Re: Alaskan_TA]
#2212082
12/11/16 09:16 PM
12/11/16 09:16 PM
71TA
Warren, MI
Hollering Tried PM but says you aren't accepting. I am so shoot me a message. PS What are the hoses to going thru that 2 hole grommet. I know the 3 hole grommet is for the hidden headlights on a Charger.
[Re: NANKET]
#2212372
12/12/16 10:02 AM
12/12/16 10:02 AM
Posts: 6,393 Abilene, Texas
fastmark
Abilene, Texas
One hose goes to the vacuum storage can under the battery tray. The other goes to the vacuum diaphragm on the heater control valve. Well, this is a timely subject for me. I'm just finishing up a 70 Charger with A/C and I forget about that vacuum can. Does the hose that goes to the can have a splice in it right at the firewall or does it go all the way from the can through the grommet to the inside?
[Re: NANKET]
#2217597
12/20/16 10:04 AM
12/20/16 10:04 AM
fastmark
Abilene, Texas
That hose has a splice in it about 6" from the firewall, looked at 2 1970 cars that are pretty original. Thanks
