Hurst Shifter Linkage dragging on frame - '70 Challenger #2208539
12/06/16 02:23 AM
12/06/16 02:23 AM
Hawaii
Dodgeballs Offline OP
Hawaii
I've never had a problem like this before and I can't dind anyone else who has had it. The 4 speed shifter linkage is scraping on the frame making it hard to go through the gears. Would bad motor mounts or trans mounts be the problem?
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2208554
12/06/16 02:44 AM
12/06/16 02:44 AM
Most problems are caused by a reason, correct work When did this start happening and what changed to make it happen work scope
Good luck, let us know what you find out thumbs
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2208557
12/06/16 02:50 AM
12/06/16 02:50 AM
Hawaii
Hawaii
I bought the car like that. smile
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2208586
12/06/16 04:08 AM
12/06/16 04:08 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's possible that it's the mounts, but it's also possible that the rods are installed wrong (upsidedown, perhaps).
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2208603
12/06/16 05:20 AM
12/06/16 05:20 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
If the trans mount lets the trans tailhousing sit too low it could cause that. twocents
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2208704
12/06/16 02:05 PM
12/06/16 02:05 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You need a picture of your set up for us to really help you
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2208787
12/06/16 04:29 PM
12/06/16 04:29 PM
Do you know which shifter is in the car? there are several different possibilities scope
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2208800
12/06/16 04:54 PM
12/06/16 04:54 PM
Hawaii
Hawaii
I'm pretty sure it was a pistol grip hurst shifter. The guy took off the pistol grip and put on a hurst T-handle. I think it's the reverse rod that's scraping. It all just looks way to close to the frame - but I have no reference to know what it should look like. I've been doing other work on the car, so it's not in the best position to look at right now. Hopefully it will be running again in the next day or two and I can get it out of my cramped garage space so I can get under it to remove the trans mount.
I thought maybe it could be the rod upside down (can't see right now), but the guy I got it from and his brother are very mechanically inclined and I don't think they would do that.
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2208830
12/06/16 05:44 PM
12/06/16 05:44 PM
A Red State
A Red State
This pic should give you an idea of what the shifter linkage looks like.
The 1st/2nd and 3rd/4th rods go through the shifter tunnel.
The reverse rod goes underneath the crossmember on an E=Body.
Another pic.
If the forward gear shift rods are dragging the crossmember it sounds like a sagged trans mount.
If the reverse rod doesn't go underneath the crossmember it's the wrong reverse rod and possibly the wrong shifter.
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: SNK-EYZ] #2208841
12/06/16 05:59 PM
12/06/16 05:59 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Originally Posted By SNK-EYZ
If the trans mount lets the trans tail-housing sit too low it could cause that. twocents
Had this happen on the Challenger. Replacing the transmission mount raised the tail-shaft and stopped the trans from popping out of gear.
Wish I took pics as I wonder what application that mount was for.
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2208869
12/06/16 06:37 PM
12/06/16 06:37 PM
Hawaii
Hawaii
Thank you very much for that picture. The reverse rod does go under the crossmember and the forward rods are dragging on the part of the frame where the crossmember bolts to it. The exhaust is in the way, but it kinda looks like the bolt through part of the trans mount has slipped up to the top of the hole in the mount. Looks like that could be it and will confirm as soon as I get her out of the garage.
Thanks for the help everyone!
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2209087
12/07/16 12:36 AM
12/07/16 12:36 AM
A Red State
A Red State
A stock type trans mount.
Polyurethane style.
Either way the bolt should go through the center.
If the bolt is going through the upper part the mount is bad.
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2209100
12/07/16 12:46 AM
12/07/16 12:46 AM
Outside
thedriver Offline
thedriver  Offline
Outside
Spend the extra $20 or whatever it is for the poly trans mount, the factory style rubber doesn't last very long (junk lol)
1973 challenger
Dana. 4 speed. Low deck.
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2209176
12/07/16 05:19 AM
12/07/16 05:19 AM
Hawaii
Hawaii
It was the trans mount that was collapsed. Changed it and no more scraping.
Thanks for the help again!
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: SNK-EYZ] #2209177
12/07/16 05:24 AM
12/07/16 05:24 AM
Hawaii
Hawaii
I was trying to describe that the center where the bolt goes through had moved to the top as the mount was broken.
Polyurethane style.
Re: Hurst Shifter Linkage dragging on frame - '70 Challenger [Re: Dodgeballs] #2209201
12/07/16 10:27 AM
12/07/16 10:27 AM
A Red State
A Red State
