Re: Hurst Shifter Linkage dragging on frame - '70 Challenger
[Re: Dodgeballs]
#2208830
12/06/16 05:44 PM
12/06/16 05:44 PM
Posts: 10,142 A Red State
SNK-EYZ
A Red State
This pic should give you an idea of what the shifter linkage looks like. The 1st/2nd and 3rd/4th rods go through the shifter tunnel. The reverse rod goes underneath the crossmember on an E=Body. Another pic. If the forward gear shift rods are dragging the crossmember it sounds like a sagged trans mount. If the reverse rod doesn't go underneath the crossmember it's the wrong reverse rod and possibly the wrong shifter.
[Re: SNK-EYZ]
#2208841
12/06/16 05:59 PM
12/06/16 05:59 PM
Posts: 2,734 541 slobovia
A990
541 slobovia
If the trans mount lets the trans tail-housing sit too low it could cause that. Had this happen on the Challenger. Replacing the transmission mount raised the tail-shaft and stopped the trans from popping out of gear. Wish I took pics as I wonder what application that mount was for.
[Re: Dodgeballs]
#2209087
12/07/16 12:36 AM
12/07/16 12:36 AM
SNK-EYZ
A Red State
A stock type trans mount. Polyurethane style. Either way the bolt should go through the center. If the bolt is going through the upper part the mount is bad.
[Re: Dodgeballs]
#2209100
12/07/16 12:46 AM
12/07/16 12:46 AM
Posts: 1,481 Outside
thedriver
Outside
Spend the extra $20 or whatever it is for the poly trans mount, the factory style rubber doesn't last very long (junk lol)
1973 challenger Dana. 4 speed. Low deck.
[Re: SNK-EYZ]
#2209177
12/07/16 05:24 AM
12/07/16 05:24 AM
Posts: 469 Hawaii
Dodgeballs
Hawaii
I was trying to describe that the center where the bolt goes through had moved to the top as the mount was broken. A stock type trans mount. Polyurethane style. Either way the bolt should go through the center. If the bolt is going through the upper part the mount is bad.
