Low Mount Alternator bracket
#2204382
11/29/16 01:00 PM
11/29/16 01:00 PM
Posts: 299 CA
David Lee
CA
Please excuse me if I have placed this in the wrong forum.
I am looking for a low mount alternator setup that will allow the use of the small denso alternator on a small block in my 67 cuda. I just need to have it run off the crank pulley since I will be running an electric water pump
Ah...so many pedestrians, so little time...
Re: Low Mount Alternator bracket
[Re: David Lee]
#2204438
11/29/16 02:26 PM
11/29/16 02:26 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
No one makes a low mount alt. bracket for a small block. I talked to DMI about it, he said he might make one at some point but did not have anything in the works. I have the exact setup you are referring to with a Moroso electric pump. I used the AR Engr. brackets that came in the kit with the alt. My neighbor is a machinist and he made me some standoffs to get the alt. to sit where it lined up with the crank pulley. They are counter bored to fit snugly into the water pump housing.
'71 Duster '17 Ram 1500
[Re: 1974 474 Duster]
#2204463
11/29/16 02:56 PM
11/29/16 02:56 PM
RMCHRGR
Spahn Ranch
OP was asking about a small block application. Plenty of choices out there for low mount alt. on a big block, none for a small block. Zero.
#2204542
11/29/16 04:49 PM
11/29/16 04:49 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I used a Power Master BB/Chevy on mine. Both w/elephant ears & a motor plate. Worked out good for me. Thanks, Ken What is that mount made from?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: David Lee]
#2204547
11/29/16 04:53 PM
11/29/16 04:53 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I gave up and did this, works like a charm.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: David Lee]
#2204601
11/29/16 06:13 PM
11/29/16 06:13 PM
Posts: 7,506 Az
Crizila
Az
Sm blk, gotta make your own.
Fastest 300
[Re: David Lee]
#2204829
11/29/16 11:48 PM
11/29/16 11:48 PM
RMCHRGR
Spahn Ranch
I contacted Bullet when I was looking for one, never heard back. Does look like a nice piece, would have made things a lot easier for me. But, like most have said, it's probably best to come up with something on your own. I started to make one for the driver's side but changed directions and abandoned the idea.
[Re: Headhunter22]
#2205617
12/01/16 12:24 AM
12/01/16 12:24 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Here is mine. It mounts my crank trigger also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: David Lee]
#2205952
12/01/16 05:14 PM
12/01/16 05:14 PM
RMCHRGR
Spahn Ranch
I spoke with Mazzolini about that bracket. He said he lost contact with the cat who made it. I believe it may have even been someone on here. Just for the record, that bracket was not a low mount but compensated for the lack of mounting points when you ditch the mechanical water pump. In theory, the method I use is the same but I'm using a two piece bracket where the one Mazzolini had was one solid piece. Member OneBadFish has one, he posted the pic below in an older thread.
[Re: David Lee]
#2206016
12/01/16 07:32 PM
12/01/16 07:32 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
That is an old pic from maybe 2010 or so? I still use the bracket though it works great. I have thought about having a copy made locally just to have a spare.
When Bob originally started selling it I called him ASAP and got one ordered, I had a really ugly setup on there before haha. I think the member that designed it was Sloan and I think his user name is now PUNK.
68 Barracuda Formula S 340
[Re: moparx]
#2208700
12/06/16 02:01 PM
12/06/16 02:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The one off the fuel pump plate is the type I did but I made a bracket to lower it farther... still mounts to the pump plate EDIT you cant see the bracket but you get a idea of the location of the alt
