Low Mount Alternator bracket #2204382
11/29/16 01:00 PM
11/29/16 01:00 PM
CA
David Lee Offline OP
CA
Please excuse me if I have placed this in the wrong forum.
I am looking for a low mount alternator setup that will allow the use of the small denso alternator on a small block in my 67 cuda. I just need to have it run off the crank pulley since I will be running an electric water pump
Ah...so many pedestrians, so little time...
Re: Low Mount Alternator bracket [Re: David Lee] #2204438
11/29/16 02:26 PM
11/29/16 02:26 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
No one makes a low mount alt. bracket for a small block. I talked to DMI about it, he said he might make one at some point but did not have anything in the works.
I have the exact setup you are referring to with a Moroso electric pump. I used the AR Engr. brackets that came in the kit with the alt.
My neighbor is a machinist and he made me some standoffs to get the alt. to sit where it lined up with the crank pulley. They are counter bored to fit snugly into the water pump housing.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Low Mount Alternator bracket [Re: RMCHRGR] #2204441
11/29/16 02:30 PM
11/29/16 02:30 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
I used a Power Master BB/Chevy on mine. Both w/elephant ears & a motor plate. Worked out good for me.
Thanks, Ken
Re: Low Mount Alternator bracket [Re: 1974 474 Duster] #2204463
11/29/16 02:56 PM
11/29/16 02:56 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
OP was asking about a small block application. Plenty of choices out there for low mount alt. on a big block, none for a small block. Zero.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Low Mount Alternator bracket [Re: David Lee] #2204493
11/29/16 03:58 PM
11/29/16 03:58 PM
AndyF Offline
AndyF  Offline
I make a bracket that hangs off of a motor plate for the SB. I also made a low mount bracket for a SB that hung off of the fuel pump boss. So there are ways to do it but nothing off the shelf.
Re: Low Mount Alternator bracket [Re: 1974 474 Duster] #2204542
11/29/16 04:49 PM
11/29/16 04:49 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Thanks, Ken
What is that mount made from?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Low Mount Alternator bracket [Re: David Lee] #2204547
11/29/16 04:53 PM
11/29/16 04:53 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I gave up and did this, works like a charm.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Low Mount Alternator bracket [Re: David Lee] #2204601
11/29/16 06:13 PM
11/29/16 06:13 PM
Az
Crizila Offline
Crizila  Offline
Az
Sm blk, gotta make your own.
Fastest 300
Re: Low Mount Alternator bracket [Re: Crizila] #2204810
11/29/16 11:27 PM
11/29/16 11:27 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
http://www.bulletcylinderheads.com.au/bullet_components/?ids=11
I looked at making them, but these guys make a nice piece
Alan Jones
Re: Low Mount Alternator bracket [Re: David Lee] #2204825
11/29/16 11:42 PM
11/29/16 11:42 PM
AndyF Offline
AndyF  Offline
Here is my low mount setup on a motor plate.
Re: Low Mount Alternator bracket [Re: David Lee] #2204829
11/29/16 11:48 PM
11/29/16 11:48 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I contacted Bullet when I was looking for one, never heard back.
Does look like a nice piece, would have made things a lot easier for me.
But, like most have said, it's probably best to come up with something on your own. I started to make one for the driver's side but changed directions and abandoned the idea.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Low Mount Alternator bracket [Re: RMCHRGR] #2205068
11/30/16 06:23 AM
11/30/16 06:23 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
i done a ruff one here
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Low Mount Alternator bracket [Re: David Lee] #2205613
12/01/16 12:18 AM
12/01/16 12:18 AM
Lawton, MI
Headhunter22 Offline
Lawton, MI
Mazzolini used to make one, called him a few years ago about another run. Nothing materialized so I just ended up just making one with a powemaster bracket. I'd post a pic but it's in pieces now.
Re: Low Mount Alternator bracket [Re: Headhunter22] #2205617
12/01/16 12:24 AM
12/01/16 12:24 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Here is mine. It mounts my crank trigger also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Low Mount Alternator bracket [Re: David Lee] #2205952
12/01/16 05:14 PM
12/01/16 05:14 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I spoke with Mazzolini about that bracket. He said he lost contact with the cat who made it. I believe it may have even been someone on here.
Just for the record, that bracket was not a low mount but compensated for the lack of mounting points when you ditch the mechanical water pump.
In theory, the method I use is the same but I'm using a two piece bracket where the one Mazzolini had was one solid piece. Member OneBadFish has one, he posted the pic below in an older thread.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Low Mount Alternator bracket [Re: David Lee] #2206016
12/01/16 07:32 PM
12/01/16 07:32 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is an old pic from maybe 2010 or so? I still use the bracket though it works great. I have thought about having a copy made locally just to have a spare.
When Bob originally started selling it I called him ASAP and got one ordered, I had a really ugly setup on there before haha. I think the member that designed it was Sloan and I think his user name is now PUNK.
68 Barracuda Formula S 340
Re: Low Mount Alternator bracket [Re: Bad340fish] #2208138
12/05/16 03:10 PM
12/05/16 03:10 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
here is another option
It's a bigblock with a torque flight!!!
Re: Low Mount Alternator bracket [Re: mopar_to_ya] #2208693
12/06/16 01:40 PM
12/06/16 01:40 PM
moparx Offline
moparx  Offline
now that is one i'll try to remember in my foggy, old mind ! pretty slick !
beer
Re: Low Mount Alternator bracket [Re: moparx] #2208700
12/06/16 02:01 PM
12/06/16 02:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The one off the fuel pump plate is the type I did
but I made a bracket to lower it farther... still
mounts to the pump plate
EDIT
you cant see the bracket but you get a idea of the
location of the alt
wave
Re: Low Mount Alternator bracket [Re: 1967dartgt] #2208701
12/06/16 02:01 PM
12/06/16 02:01 PM
My mount is the big block chevy billet mount by powemaster
/ken
