Re: BB DROP IN WATER PUMPS...............
[Re: Thumperdart]
#2205208
11/30/16 01:43 PM
11/30/16 01:43 PM
Posts: 1,462 Martinsville, IN
cdwmotorsports
Martinsville, IN
Yeah, I had one of the old moroso motors with the little ribbed plate, luckily I lost some of the parts and "had" to have a new water pump
eBay-cdwmotorsports
[Re: Thumperdart]
#2205212
11/30/16 01:46 PM
11/30/16 01:46 PM
Posts: 1,260 Netherlands
72Challenger
Netherlands
Used a 'mancini racing version' of that meziere and worked flawles for many years of street / strip. 199 $ it is.
[Re: Jeremiah]
#2205280
11/30/16 03:36 PM
11/30/16 03:36 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
CVR pn 6540, 55 GPM. They are around $230. I've got this one as well. Works good so far.
[Re: indcontrols]
#2205370
11/30/16 05:59 PM
11/30/16 05:59 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
I got the Summit one, $219 - works great. Summit brand here also. It has a Summit sticker on it and it also has CVR cast into it. Worked well for many years. I use it for race only unit though
[Re: cdwmotorsports]
#2205375
11/30/16 06:02 PM
11/30/16 06:02 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
This is the pump I run also. Works great...was a Christmas present to myself in '07. Still working. The CVR pump recommended above moves more water than the Meziere. CVR seems to be good quality too, so if I was buying a new one today...it'd be the CVR.
[Re: FastmOp]
#2205398
11/30/16 07:02 PM
11/30/16 07:02 PM
Thumperdart
State of confusion
Do you have the Aluminum housing? Yes sir.............Looks like CVR then.............
[Re: Thumperdart]
#2205415
11/30/16 07:29 PM
11/30/16 07:29 PM
an8sec70cuda
The Summit brand pumps are only shown in 30 and 35 GPM from what I saw on the website. Might have to get the CVR pump for the 55 GPM.
The "drop-in" Meziere like I have is 42 GPM. Meziere makes a big one that has the housing and all made onto it and it flows 55 GPM I believe, but it's almost $600!
[Re: Thumperdart]
#2205436
11/30/16 08:10 PM
11/30/16 08:10 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
If they go bad its just like a mechanical pump going bad, your screwed! lol
I have run one on the street for years and for long drives with no trouble. I did have one fail but it never quit outright, it had a bad winding in the armature and would not always start right away and it ran slower than it should.
68 Barracuda Formula S 340
[Re: Thumperdart]
#2205775
12/01/16 11:47 AM
12/01/16 11:47 AM
an8sec70cuda
BradH...Like Bad340 said, no different than a mechanical pump going bad, you're screwed either way. My Meziere pump is almost 10 years old and has a ton of time on it...still working great. We had a Weiand electric pump go bad on the Camaro last year...it still worked, but was making some awful grinding noises. Heard it when I got back to the trailer and shut the car off to let it cool. That pump had a lot of time on it too, although it was race only.
I may differ from a lot of folks, but I like everything wired on toggle switches. Just a normal relay and a toggle switch, flip it on once the motor is cranked and running clean. Then leave it on for a few minutes after I shut it off to cool it down good. That's REAL nice at the track as long as your battery is up to par.
