Page 1 of 3 1 2 3
BB DROP IN WATER PUMPS............... #2205191
11/30/16 01:18 PM
11/30/16 01:18 PM
State of confusion
Thumperdart Offline OP
State of confusion
Checked on a rebuild kit for my old Moroso 63575 elec. pump and no can do so what are you street/strip guys running............. thumbs
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205202
11/30/16 01:31 PM
11/30/16 01:31 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
eBay-cdwmotorsports
Re: BB DROP IN WATER PUMPS............... [Re: cdwmotorsports] #2205206
11/30/16 01:42 PM
11/30/16 01:42 PM
State of confusion
State of confusion
That's a good price and cheaper than my dated/heavy Moroso..........Christmas gift to myself........thankxxx........... XmasPeng
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205208
11/30/16 01:43 PM
11/30/16 01:43 PM
Martinsville, IN
Martinsville, IN
Yeah, I had one of the old moroso motors with the little ribbed plate, luckily I lost some of the parts and "had" to have a new water pump
eBay-cdwmotorsports
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205212
11/30/16 01:46 PM
11/30/16 01:46 PM
Netherlands
72Challenger Offline
Netherlands
Used a 'mancini racing version' of that meziere and worked flawles for many years of street / strip. 199 $ it is.
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205229
11/30/16 02:14 PM
11/30/16 02:14 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Year one has 30% off and that brings new Moroso to 237 if my math is correct
Re: BB DROP IN WATER PUMPS............... [Re: cdwmotorsports] #2205257
11/30/16 03:07 PM
11/30/16 03:07 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Originally Posted By cdwmotorsports
Yep, same one I bought and it will move some water.
Re: BB DROP IN WATER PUMPS............... [Re: Scamp408] #2205260
11/30/16 03:09 PM
11/30/16 03:09 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
CVR pn 6540, 55 GPM. They are around $230.
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205264
11/30/16 03:14 PM
11/30/16 03:14 PM
South Florida
indcontrols Offline
indcontrols  Offline
South Florida
I got the Summit one, $219 - works great.
Re: BB DROP IN WATER PUMPS............... [Re: Jeremiah] #2205280
11/30/16 03:36 PM
11/30/16 03:36 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I've got this one as well. Works good so far.
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205307
11/30/16 04:31 PM
11/30/16 04:31 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Do you have the Aluminum housing?
Re: BB DROP IN WATER PUMPS............... [Re: indcontrols] #2205370
11/30/16 05:59 PM
11/30/16 05:59 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Summit brand here also. It has a Summit sticker on it and it also has CVR cast into it. Worked well for many years. I use it for race only unit though
Re: BB DROP IN WATER PUMPS............... [Re: cdwmotorsports] #2205375
11/30/16 06:02 PM
11/30/16 06:02 PM
an8sec70cuda Offline
This is the pump I run also. Works great...was a Christmas present to myself in '07. Still working.
The CVR pump recommended above moves more water than the Meziere. CVR seems to be good quality too, so if I was buying a new one today...it'd be the CVR.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: BB DROP IN WATER PUMPS............... [Re: FastmOp] #2205398
11/30/16 07:02 PM
11/30/16 07:02 PM
State of confusion
State of confusion
Yes sir.............Looks like CVR then............. thumbs
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205410
11/30/16 07:23 PM
11/30/16 07:23 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Back when I bought my Summit one, it was just a rebranded CVR pump. You can probably save a few bucks and buy the Summit brand pump if you're looking at the CVR.
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205415
11/30/16 07:29 PM
11/30/16 07:29 PM
The Summit brand pumps are only shown in 30 and 35 GPM from what I saw on the website. Might have to get the CVR pump for the 55 GPM.
The "drop-in" Meziere like I have is 42 GPM. Meziere makes a big one that has the housing and all made onto it and it flows 55 GPM I believe, but it's almost $600!
CHIP
Re: BB DROP IN WATER PUMPS............... [Re: an8sec70cuda] #2205422
11/30/16 07:53 PM
11/30/16 07:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
How do the 'lectric pumps work during regular street use? Do you need to have them wired through a thermostat that switches 'em off/on depending upon the water temp? I know they free up a few HP, but how much of a PITA is it to set one up? And if they do go bad 100 miles from home... shruggy
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205436
11/30/16 08:10 PM
11/30/16 08:10 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If they go bad its just like a mechanical pump going bad, your screwed! lol
I have run one on the street for years and for long drives with no trouble. I did have one fail but it never quit outright, it had a bad winding in the armature and would not always start right away and it ran slower than it should.
68 Barracuda Formula S 340
Re: BB DROP IN WATER PUMPS............... [Re: Bad340fish] #2205508
11/30/16 10:14 PM
11/30/16 10:14 PM
State of confusion
State of confusion
It worked great for well over 10 years iirc and just noticed the noise when the car was OFF otherwise you definitely can't hear it..... laugh2 I heard mine only flowed 28 and it was marginal in vegas last summer in 114+ heat so more flow hopefully more cool.............Brad, they're great on the street and as most know, I don't race much..........lmao............ biggrin
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2205775
12/01/16 11:47 AM
12/01/16 11:47 AM
BradH...Like Bad340 said, no different than a mechanical pump going bad, you're screwed either way. My Meziere pump is almost 10 years old and has a ton of time on it...still working great.
We had a Weiand electric pump go bad on the Camaro last year...it still worked, but was making some awful grinding noises. Heard it when I got back to the trailer and shut the car off to let it cool. That pump had a lot of time on it too, although it was race only.
I may differ from a lot of folks, but I like everything wired on toggle switches. Just a normal relay and a toggle switch, flip it on once the motor is cranked and running clean. Then leave it on for a few minutes after I shut it off to cool it down good. That's REAL nice at the track as long as your battery is up to par.
CHIP
Page 1 of 3 1 2 3
